Author Topic: main beam relay location omega 2.2 52 plate  (Read 4050 times)
brian1948
  • twickenham
    • omega
« on: 08 December 2014, 12:21:16 »
can anyone tell me the location of the main beam relay as my lights are stuck on dip and i cannot get the main beam to work or the main beam flash
chrisgixer
Re: main beam relay location omega 2.2 52 plate
« Reply #1 on: 08 December 2014, 13:04:51 »
Fuse box under steering wheel. At the very top. Small black relay.
On elites there's two. Tother is self levelling pump. Not sure how yours will be configured.
brian1948
  • twickenham
    • omega
« Reply #2 on: 08 December 2014, 13:40:46 »
thanks for that,if i take the relay out will the dip beam go off or would it stay on as when i take it out the dip beam stays on,thanks brian
« Reply #3 on: 08 December 2014, 17:32:02 »
It'll go off when you pull relay :y
You should hear it click when you flash headlights, which will help identify which of the 2 small ones at the top it is. Earlier cars have it marked on fusebox lid
The Sheriff
« Reply #4 on: 08 December 2014, 17:35:25 »
It might not click. That might be the problem  :P :P :P
« Reply #5 on: 08 December 2014, 17:40:50 »
Errr, good point, well presented  :-[
brian1948
  • twickenham
    • omega
« Reply #6 on: 08 December 2014, 18:44:40 »
if that is not the problemmi have renewd the stalk and all the fuses are ok,what else do i need to check,thanks
« Reply #7 on: 08 December 2014, 19:45:59 »
Assuming everything else is working OK, the only thing is fuses (F21 and F32), stalk, main light switch, high beam relay or wiring.
brian1948
  • twickenham
    • omega
« Reply #8 on: 10 December 2014, 13:29:16 »
i have renewed the stalk checked the fuses and renewed the small relay box,also checked the main beam bulbsmbut all i get when i turn on the main beam headlights is the dip lights which do not go off
when you switch the the lights,when i also pull out the small relay box the dip lights do not go off,is there another relay box under the bonnet somewhere,or should i check somewhere else,any suggestions would be grateful
« Reply #9 on: 10 December 2014, 14:41:45 »
Where did the switch come from?
brian1948
  • twickenham
    • omega
« Reply #10 on: 10 December 2014, 14:56:16 »
vauxhall
« Reply #11 on: 10 December 2014, 15:19:08 »
Ok, rules that out...
Headlight switch to sidelights = a single 5w light in each headlight cluster.
Headlight switch fully on = as above plus outboard head lights lit.
Indicator switch forward with headlight switch fully on = main beam on. Should then have four headlights and side lights visible.
Indicator switch pulled back should flash the inner pair of lights regardless of headlight switch position...
brian1948
  • twickenham
    • omega
« Reply #12 on: 10 December 2014, 15:46:50 »
that is correct,but the main beam does not come on and the main beam flash does not operate
« Reply #13 on: 10 December 2014, 15:58:07 »
Last post might have been a bit patronising, not meant to be, but was trying to clarify your previous post :y
Sounds like the switch is a dud... :-\
« Reply #14 on: 10 December 2014, 18:06:59 »
Can't be main fuse links, as loads of other shite wouldn't work. Now at stage of needing a meter on it. Shame I'm too far away
Page created in 0.038 seconds with 20 queries.
