Author Topic: Been doing some LPG tweaking :)  (Read 1666 times)
« on: 27 June 2008, 21:39:17 »
I've been playing with the LPG install tonight trying to fine tune it. This is the first decent session I've had with the laptop.
First observation was that the multipliers were unusually high following autocalibration, and every time I pushed the engine past 4k revs it would flag a fault that the injectors were fully open.
I gave the car some beans and the lambda was reading 0v at WOT, meaning it's running lean. Can't carry on like that - could hole a piston.
Sooo.. decide the nozzles need to go out a bit bigger. When I first converted I drilled them to 2mm, so I took them out to 2.5mm. Doesn't seem a lot but when you compare the difference by eye it's a fair bit and you'll get a lot more volume of gas through there.
Also decided to up the pressure, I've taken it from about 0.79 to 1.09.
After these two tweaks I calibrated again, and went for a drive. I instantly noticed a big increase in performance. I can now rev to the redline before it warns about the injectors being fully open, and when I gave it a good spanking in all the gears joining a motorway (redline in 3rd ::) ) it logged a consistent 4.5 volts on the lambda - so it's no longer lean.
Mapping was pretty close, I tweaked this a bit.
Seems to run really nicely now - tomorrow will be the acid test :y
Re: Been doing some LPG tweaking :)
« Reply #1 on: 27 June 2008, 21:40:48 »
I can now drive it right through the rev range the same as if it's on petrol and you can't tell the difference between the two fuels.. in fact, it seems more pokey on gas!
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #2 on: 27 June 2008, 21:55:19 »
i have my injectors currently at 2.5 and we still have this jolt at high revs.
Multipliers are high on mine as well and i get errors on WOT about injectors being open.
Might have a got at taking my injectors out to 3.0mm tomorrow and see if that helps
we ave set my vaporiser up at 1.2 bar as well, when i first got it it had been set at .8 bar
« Reply #3 on: 27 June 2008, 22:15:30 »
Noticed the time of your post James, do you ever stop......... :D
« Reply #4 on: 27 June 2008, 22:26:47 »
Which post? ::)
Taxi_Driver
« Reply #5 on: 27 June 2008, 22:48:30 »
Bet your using more lpg now  ::) :-/
Prob the reason my 2.2 is a bit underpowered on lpg........i originally complained to the installer it was underpowered.....he told me he could 'up' it but i would use more lpg........so decided against it........ecu constantly complains of lean mixture on the lambda's but ive nearly done 100k since and its still going  :y
SteveD
  • Blackpool (no casino)
« Reply #6 on: 27 June 2008, 23:03:53 »
Apoogies for hijacking :-/
Is this on your 2.6 with one of Jeremy's kits?
I'm going to install the front end on My 3.0 this weekend so might drill them out before I fit them for the first time.
Cheers
sassanach
  • trowbridge
« Reply #7 on: 27 June 2008, 23:06:35 »
bore them out to at least 3mm.
SteveD
« Reply #8 on: 27 June 2008, 23:10:29 »
Is that what you have yours at?
Are you running the vap at 1 bar or have you had to up that too?
Cheers
sassanach
  • trowbridge
« Reply #9 on: 27 June 2008, 23:16:48 »
on my omega i have a omvl setup but i had to drill them out to 3.3mm.
on my caddy i have jeremys setup which i run at 3.2mm (maxed out) with the vapouriser at 1.7 bar.transfers back to petrol at 5000rpm,basically because it cant throw the gas in fast enough!!!!
Martin_1962
« Reply #10 on: 28 June 2008, 10:21:56 »
I had to back off the mixture on WOT on my Romano kit until it didn't cut out on load, it is slightly lean but AGWW recommended this
rickyboy
  • Glasgow
« Reply #11 on: 28 June 2008, 10:28:10 »
Do you not have the option to turn the over-run feature on and off to stop it switching back to petrol?
