Author Topic: Tips for Brakes that have been stood a while..?  (Read 1577 times)
Diamond Black Geezer
    • & a silly coupe coming...
« on: 09 December 2014, 10:32:47 »
Next on the list, once my new HT leads arrive, and she's running nicely, will be suspension and brakes, one corner at a time. I'm guessing I'll be looking at changing the brake fluid too, also got some pads and discs, but when it comes to the calipers I'm thinking -
I pump all the way in, (nearly) all the way out,
check for corrosion/bad perished seals.
check for damage to hoses
Aiming to give them good clean up, and to paint them too. So thinking that this would be a perfect time to replace brake fluid, if the calipers are off the old girl for painting.
Anything I've missed?
Thanks in advance, here's my favourite Christmas smiley  :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Tips for Brakes that have been stood a while..?
« Reply #1 on: 09 December 2014, 10:42:20 »
Wheel off
Split calliper and carrier.
Pads out and bin them.
Check for any damage to the rubber boots / any sign of fluid.
Make sure the piston moves in and out a little (with the reservoir top off)
Wire brush the calliper / carrier clean.
Smear a little bit of copperslip on the surface were the new pads fit / slide.
Rebuild
Don't hammer the pads for a few miles or until you get your brake feel back.
Painting a totally gay colour is optional  :D
« Reply #2 on: 09 December 2014, 11:18:33 »
Wheel off
Rebuild
Cheers, that's what I'd call a 'proper' answer, nice and traditional old-fashioned real mechanic-ing  :)
Also you'll be happy to learn the colour I'm going for... silver... the very best match as they came out the factory I can find.  :y
Or pink with lilac spots.. one or the other.
« Reply #3 on: 09 December 2014, 12:03:09 »
Red paint for calipers but after a while they turn pink with the heat  ;D
The Sheriff
« Reply #4 on: 09 December 2014, 12:27:08 »
Like old corsas and astras  ;D
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #5 on: 09 December 2014, 14:07:40 »
Wheel off
Rebuild
Nah, pink with yellow spots would look great in a Mr Blobby sort of way  ;D ;D
