Author Topic: Thermostat V6  (Read 2914 times)
X30XE
  • UK
    • 740i,728i,S320 & Disco
Thermostat V6
« on: 10 December 2014, 19:34:29 »
Does anybody happen to know the tradeclub going rate for a V6 Thermostat?
TC website is the most useless heap ever.
Might as well order the HBV and Crank sensor now... nothing if not predictable these old cra... I mean wonderful cars.
Omegatitis : [in remission]
Re: Thermostat V6
« Reply #1 on: 10 December 2014, 19:35:55 »
I don't think its a TC item.
Last one I bought was around £50 by time it had the VAT on, but that was 2 or 3 years ago.
X30XE
  • UK
Re: Thermostat V6
« Reply #2 on: 10 December 2014, 19:46:40 »
WHAT!!  :o  :o Cheaper to buy a new car.
Ebay it is then.  >:(
Thanks TB
Re: Thermostat V6
« Reply #3 on: 10 December 2014, 20:51:46 »
US ebay is your friend if you want genuine... bought an AC Delco boxed GM one delivered within a week for £35 all in :y
You can buy pattern from £15 :y
Re: Thermostat V6
« Reply #4 on: 10 December 2014, 22:46:49 »
Thanks TB
A thermostat is a similar price for a Smart  ;) But when you buy your cheap 'stat, bare in mind how easy it is to change.  ::)
serek
  • huntingdon
    • 3.2 mv6
Re: Thermostat V6
« Reply #5 on: 10 December 2014, 23:19:24 »
Febi cost about 35 or you can buy just insert for about 10
Re: Thermostat V6
« Reply #6 on: 10 December 2014, 23:29:52 »
Reusing housing and transfer pipe is a gamble and depends on being able to separate them without breaking either of them. Given the odds of that happening, best budget for both new imho :y
X30XE
  • UK
Re: Thermostat V6
« Reply #7 on: 10 December 2014, 23:39:28 »
http://www.ebay.co.uk/itm/181461149422
Have gone for one of these puppies.
Although I am concerned about the transfer pipe. Is it an O-ring seal between the two?
serek
  • huntingdon
    • 3.2 mv6
Re: Thermostat V6
« Reply #8 on: 10 December 2014, 23:46:24 »
There is 2 o rings, but transfer pipe cost 13 with 0 rigs from vxl
X30XE
  • UK
Re: Thermostat V6
« Reply #9 on: 10 December 2014, 23:50:21 »
Cool. I'll get that.  Which coolant did you use when you did the waterpump for me, as I'll be needing to top it up and i'd rather not mix types?  Thanks
serek
  • huntingdon
    • 3.2 mv6
Re: Thermostat V6
« Reply #10 on: 11 December 2014, 00:00:51 »
Pink . can mix with vxl one no problem
X30XE
  • UK
Re: Thermostat V6
« Reply #11 on: 11 December 2014, 00:06:04 »
Cool. Thanks.
