Author Topic: Struggling to remove screws holding dispack 2000 2.5 petrol  (Read 2219 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
I suspect dispack failure causing misfire. Screws are Torx E10. There is not room between head and dispack for my standard socket. 8mm socket not holding. I guess I need a deep E10 socket. Is there any other way?
Re: Struggling to remove screws holding dispack 2000 2.5 petrol
« Reply #1 on: 13 December 2014, 21:00:19 »
Pretty sure I used a 1/4" drive 8mm socket on a long-ish extension
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #2 on: 13 December 2014, 21:08:04 »
I found a swivel joint helpful when doing my old one, it was -9 at the time too :o
« Reply #3 on: 13 December 2014, 21:47:04 »
Once loosened i found a strong telescopic magnet is ideal for lifting the screws/bolts out , it even turns them the last few threads so you dont drop them . Best bit of kit i ever bought  :) Swivel joint helps on an extension for undoing .
symes
  • oxford
    • R reg 940 volvo
« Reply #4 on: 13 December 2014, 22:46:15 »
You need 1/4 drive 3 inch extension bar and 8mm socket---to remove dispack :y :y :y
chrisgixer
« Reply #5 on: 14 December 2014, 00:26:37 »
Long time since I did one, but is it not a case of undoing three, twisting the dis pac, which then gives room to access/loosens the fourth...? Or am I thinking of sumat else....? :-\
Deep socket not needed as far as the depth of the bolt head is concerened.
« Reply #6 on: 14 December 2014, 00:51:50 »
Arms like Mr Tickle are helpful as well!  ;)  ;D
« Reply #7 on: 14 December 2014, 01:41:07 »
+1 :y :y
« Reply #8 on: 14 December 2014, 08:26:44 »
Not needed for traditional reasons, as its just a torx bolt, but being longer, it acts as a short extension. IIRC, anyway. If that makes sense.
« Reply #9 on: 14 December 2014, 08:29:11 »
To the OP, I found one of the most useful "tools" for dispack removal is a "tunnie"....
« Reply #10 on: 14 December 2014, 14:31:45 »
Who's the young bloke on the left ;D
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #11 on: 14 December 2014, 19:55:30 »
Haha love that photo. Del Boy n rodders  ;D
I find it so much easier to remove plenum then remove inlets. . . You can then get a hand in round the corner of the head. Quite a bit if room.
RIP Paul Lovejoy
chrisgixer
« Reply #12 on: 14 December 2014, 20:54:26 »
So extension required, no?
terry paget
    • 3 Astras 2 Vectra
« Reply #13 on: 15 December 2014, 08:39:59 »
Having failed to remove the inside screws with my E10 torx socket and my 8mm deep socket, I popped into Machine Mart and bought a set of deep Torx sockets, 3/8" drive. While there, I prowled around buying odd items for my kids to give me for Christmas, rather than have them buy me junk. One item I picked off the shelves was an 8 piece  set of deep multifit metric sockets 1/4" drive. Label claims it will fit square, double hex, spline, torx and hex heads. bold claim I thought.
Got home, attacked the DISpack screws with my deep torx sockets, no success. Sockets were not deep enough, and the 3/8" heads fouled a plate on the cylinder head. In desperation I opened the above fit-everything pack, found the right socket, and tried it. It worked! Secret was its 1/4" drive, therefore slim.
For £8.39 it was money well spent. Catalogue number 040215225. Might be worth adding to your present lists.
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #14 on: 15 December 2014, 08:47:36 »
Better order quick or stock will be exhausted by oofs :y
