Pages: 1 2 3 [4] 5  All   Go Down
Author Topic: Airbag Light  (Read 17440 times)
rikki_essex
  • essex
    • 2L gls estate with lpg 20
Re: Airbag Light
« Reply #45 on: 18 January 2015, 14:40:52 »
ive just had a chance to read the codes for the airbag light and its saying the following codes
Total number of fault codes: 2
00035 - Driver Pretensioner Circuit High Resistance
Present
00037 - Passenger Pretensioner Circuit High Resistance
Present
Any idea what my next steps need to be to get it all working again? Thanks in advance Rikki
regards Rik
Re: Airbag Light
« Reply #46 on: 18 January 2015, 14:42:27 »
Present
Present
That's suspicious.  Have you changed the seats?
rikki_essex
  • essex
Re: Airbag Light
« Reply #47 on: 18 January 2015, 14:43:20 »
i havnt but i think Marie did who i bought it off
regards Rik
Re: Airbag Light
« Reply #48 on: 18 January 2015, 14:44:56 »
Ah 'dangle berries'.
Can you check if seats have side airbags (will be about halfway up rear bit).
rikki_essex
  • essex
Re: Airbag Light
« Reply #49 on: 18 January 2015, 14:59:46 »
Yes they do have airbags in them
regards Rik
Re: Airbag Light
« Reply #50 on: 18 January 2015, 15:29:06 »
Did you attempt to reset ecu?
rikki_essex
  • essex
Re: Airbag Light
« Reply #51 on: 18 January 2015, 15:31:17 »
Yes but they came straight up again
regards Rik
Re: Airbag Light
« Reply #52 on: 18 January 2015, 15:34:04 »
Check the pretensioners are plugged in, and that they haven't been activated
rikki_essex
  • essex
Re: Airbag Light
« Reply #53 on: 18 January 2015, 15:36:56 »
Sorry for sounding blond but how will I know if they have been set off
regards Rik
rikki_essex
  • essex
Re: Airbag Light
« Reply #54 on: 18 January 2015, 15:49:38 »
I've just had a quick look the only thing that is not connected is a pink connector
regards Rik
rikki_essex
  • essex
regards Rik
powerslinky
Re: Airbag Light
« Reply #56 on: 18 January 2015, 16:20:48 »
Riki  . . . I have changed a couple of sets of MV6 seats for Elite ones  & there is a problem that occurs   with the yellow connector on passenger side . This is only used on Elites for the "child seat " facility & should not be plugged in when putting Elite seats into other models  AFAIK.
 On both the MV6's I have  put Elite seats into this yellow connctor block was just taped up below the seat . The first one I changed I connected this yellow block connector & the  airbag light came on  . . . second one I did I left it unconnected & all is ok  Presume it will be the same on the GLS or any other model bar the Elite.
But in my cases I was swapping FL  into FL  not sure that is the case with yours or the yellow connector will even be laying below the seat on the GLS .Hope this makes sense  & may help :-\
EDIT:  I think RobG did post up a picture of this yellow connector  . . . but had a quick look & could not find it  :( :(
« Last Edit: 18 January 2015, 16:31:15 by Essex Big Al »
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: Airbag Light
« Reply #57 on: 18 January 2015, 16:33:54 »
powerslinky
Re: Airbag Light
« Reply #58 on: 18 January 2015, 16:37:20 »
Yellow block connector for child seat senor will not be in that picture  . .  .  as it is only on the passenger side
rikki_essex
  • essex
Re: Airbag Light
« Reply #59 on: 18 January 2015, 16:51:40 »
Ok thankyou very much for that I'll check it in the morning. Should that pink connector be plugged in anywhere. Also Al I forgot I asked you for the cruise control stalk have you still got it?
regards Rik
Pages: 1 2 3 [4] 5  All   Go Up
