Author Topic: Airbag Light  (Read 17535 times)
rikki_essex
  • essex
    • 2L gls estate with lpg 20
Airbag Light
« on: 20 December 2014, 23:14:15 »
Evening All, I need to reset the airbag light on the car and i was thinking of buying something off ebay to reset it but my car is a w reg facelift and all of the adverts are saying it will only work with post 2001 car does anyone know what i need to get instead?
regards Rik
Re: Airbag Light
« Reply #1 on: 20 December 2014, 23:41:52 »
I stand to be corrected, but having been there iirc it can't be reset, certainly not by anything you buy of ebay, I have a code reader myself, works well enough but could not reset the air bag. I needed to buy a part, but for the life of me I cant remember what the part is called, though I can picture it....... :-[ ::) ::)
I am sure someone will be along who can give a better answer, me I sold the car, never fixed the problem...... :D :D
4x4
Re: Airbag Light
« Reply #2 on: 20 December 2014, 23:43:24 »
Airbag ecu
Re: Airbag Light
« Reply #3 on: 21 December 2014, 00:04:07 »
Airbag ecu
That's the one.......... :y :y
rikki_essex
  • essex
Re: Airbag Light
« Reply #4 on: 21 December 2014, 00:06:42 »
Ok no problem can vauxhall not reset it with a tech 2. Ive only just bought the car and the only reason the light is on is because they changed the seats but forgot to wait 15 minutes before doing the job.
regards Rik
Re: Airbag Light
« Reply #5 on: 21 December 2014, 00:22:13 »
Worth a try, you need to get it sorted one way or another as it won't pass an MOT with the light on.............. ::) ::)
Re: Airbag Light
« Reply #6 on: 21 December 2014, 00:41:55 »
I bought a 'cheapo Tech II' with the Hungarian software to talk to my car .......... it reset a couple of airbags, Omega & Astra.  ;)
Re: Airbag Light
« Reply #7 on: 21 December 2014, 00:43:44 »
If it was that simple, Vauxhall would be able to reset the SRS light. If the seats have been changed, it's likely the wrong seats have been fitted iie early seats into a late car that don't have airbags
rikki_essex
  • essex
Re: Airbag Light
« Reply #8 on: 21 December 2014, 05:20:41 »
is there any way to clear the light then if that is the case
regards Rik
powerslinky
Re: Airbag Light
« Reply #9 on: 21 December 2014, 08:12:42 »
Pretty sure it's Tech 2 only to get light off. :-\     The other option ?    clocks out & remove the bulb. 10 min job ;) ;)
Apparently not an MOT failure if light does not work at all I was told :-\ :-\
My previous 2.6 MV6 had this problem after a seat change & I removed the bulb .
saw new owner just yesterday & it has since passed a new MOT with no advisories with bulb still out ;)
« Last Edit: 21 December 2014, 08:21:08 by Essex Big Al »
Re: Airbag Light
« Reply #10 on: 21 December 2014, 09:24:22 »
rikki_essex - you should have popped in on your way back down from collecting it ;)
Bulb removal is highly discouraged - if the light is on (or would be if it had a bulb), the entire SRS system is disabled.
No generic OBDII reader will clear airbags on *any* Omega.  Egay sellers universally talk shite.
Re: Airbag Light
« Reply #11 on: 21 December 2014, 09:26:48 »
Most Vauxhall specific readers should be able to either turn it off, or tell you why it can't be.
powerslinky
Re: Airbag Light
« Reply #12 on: 21 December 2014, 09:55:23 »
Bloody hell ! . . .  I didn't realise that TB   :o :o :o :o        Need mine sorting then  ::) ::) ::) ::)
Re: Airbag Light
« Reply #13 on: 21 December 2014, 10:54:22 »
Unless it's a 'cheapo Tech II'  ::)
omegod
  • liverpool
    • 2017 Seat Ateca
Re: Airbag Light
« Reply #14 on: 21 December 2014, 12:16:17 »
Your just baiting him now,  lol
