Author Topic: knocking noise n/s anti-roll bar bush  (Read 2495 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 21 December 2014, 15:43:13 »
There is a clonking in my nearside front suspension. With a son bouncing nearside corner up and down and me in the pit, I found that holding the nearside anti-roll bar near the bush, the noise stopped. My guess is that the bush is allowing the bar to hit the subframe. Ergo, the bush is knackered and needs replacing.
I hope I can do this by undoing the two screws holding the bush cap to the subframe, removing the cap and changing the bush.  Is that all there is to it? Should I change the pair while I am about it?
pauls
  • By the sea minehead
    • Bmw x3
Re: knocking noise n/s anti-roll bar bush
« Reply #1 on: 21 December 2014, 17:32:46 »
I had mine done last year with polys. As said straight forward. Fit and forget :y
terry paget
    • 3 Astras 2 Vectra
« Reply #2 on: 21 December 2014, 22:26:54 »
Has anyone done this job? Do I need to disconnect the drop links first?
« Reply #3 on: 21 December 2014, 22:33:25 »
Only thing that needs removing is the engine tray. 15 minute job :y
Bracket bolts can be done from above, but access is easier from underneath when it comes to swapping the bushes...
« Last Edit: 21 December 2014, 22:35:11 by Taxi Al »
pauls
    • Bmw x3
« Reply #4 on: 21 December 2014, 22:38:52 »
Terry Chris did mine and iam sure he just undid the two bolts slid out the old one and put in the new ones.
« Reply #5 on: 21 December 2014, 22:42:29 »
You need to loosen all four clamp bolts, then undo two fully and the clamp can be twisted from under the other bolt. Just as easy to remove both bolts tbh :y
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
« Reply #6 on: 22 December 2014, 09:49:30 »
Managed to do mine from above. o/s was easy but n/s was a bit of a knuckle scraper :y
« Reply #7 on: 22 December 2014, 10:14:30 »
The desmond has room to remove the radiator without dismantling half of the induction system... which probably helps ;)
plym ian
  • Plymouth, Devon
« Reply #8 on: 23 December 2014, 07:48:51 »
True the advantages of having a smaller engine I suppose ;D
terry paget
    • 3 Astras 2 Vectra
« Reply #9 on: 23 December 2014, 16:52:11 »
Got them both off. Haynes says put them back with the slits facing the rear of the vehicle. I found them with the slits facing forward. Does it matter? What should I do?
« Reply #10 on: 23 December 2014, 17:14:03 »
Refit as found...
terry paget
    • 3 Astras 2 Vectra
« Reply #11 on: 23 December 2014, 17:41:37 »
Refit as found...
Thanks. Will do.
terry paget
    • 3 Astras 2 Vectra
« Reply #12 on: 24 December 2014, 11:08:57 »
job done. Thanks to all for help. Took me a little more than 15 minutes, though. Every bolt was tricky to undo, then tricky to replace, different approach to every bolt.
I send seasons greeting to all forum members, and thanks for the help received during the year, especially over the clutch replacement in January. In the past I have scrapped cars when clutches failed, and I have scrapped many. Not  any more. I shall need a bit more practice before I get down to JamesV6CD's time of 4 hours though.
