Is it worth using spray on underseals to top up protection ?
Started by DrAndyB, 21 December 2014, 19:09:09
DrAndyB
    I have noticed there are a few 'spray on' underseal products about.
    Since my baby is always kept in the garage in dry (kept under her warm Duvet ;)), is it worth giving the underside a bit of TLC ?
    • Anybody used any of the spray on underseals ?
    • Is it worth doing just really to 'Keep on top of things and keep the underside protection up to scratch ?
    • Anybody recommend any brands / particular stuff ?
    I only ask since I have just had the arches and door sorted, they wax oiled the wheel arches so look brand new.  Thought I may therefore give the whole underside a spray if thought worth it ?
    Thoughts welcome and merry chrismas to all  :y
Preparation is key, regardless of the product you choose ;)
Scrape any loose edges, and use the thickest brush-on underseal you can get. Buy it from a trade supplier not Halfords.
Brushing it will give better coverage, cost less and not make (such) a mess.
tidla
Just sprayed the underside of my prized Citroen van after extensive welding with this stuff.
http://www.dinitrol.co.uk/
Used on winter maintenance gritter vehicles if that helps.
Shouldn't spray your baby with underseal mate, and most people let their babies live in their houses ;)
If you're asking about your car, then it is worth doing - advice as above, ie good preparation and brush application ;)
flyer 0712
I always use clear wax oil on top of the sound cleaned under  :y :yseal  does a great job but very messy..down you arms running into your pits .
Diamond Black Geezer
When I did my heat shield stud 'mod' (replacing sheared threads after removal of heatshields) I liberally smeared the areas of bare metal exposed after drilling / angle grinding with seam sealer. I will be going over these areas in time with a black underseal to make it all 'match'  :y
DrAndyB
Quote from: tidla on 21 December 2014, 23:49:47
Which Flavour ?  There were a few to choose from from the website, incl the E Type Jag  ;D
Thanks in advance.
Andy.
