Author Topic: Starting problem  (Read 2366 times)
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
Starting problem
« on: 22 December 2014, 18:21:58 »
Earlier I started the car and it was a little rough. Switched it off and tried restarting. The spanner light came on and it was spinning over but not firing after 2 attempts it started.
any ideas at all.
2.2 petrol
4x4
Re: Starting problem
« Reply #1 on: 22 December 2014, 18:36:03 »
Cam sensor or crank sensor
Or its having pmt  :y
« Reply #2 on: 22 December 2014, 18:37:37 »
Most likely cam sensor on the desmond... any codes :-\
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #3 on: 22 December 2014, 18:58:09 »
Had new one 4 months ago  ;D
« Reply #4 on: 22 December 2014, 18:59:19 »
Genuine  ???
Steve B
  • Leicestershire
« Reply #5 on: 22 December 2014, 19:22:46 »
« Reply #6 on: 22 December 2014, 19:24:09 »
Without codes, its simply guesswork. And here on OOF we try to instill a better diagnostics methodology :).
Sadly in this case, that does mean it needs the codes read.
If its cam sensor or crank sensor, it will fire after about 5 or 6 seconds.
If the EML is flashing, its immobiliser related.
plym ian
  • Plymouth, Devon
« Reply #7 on: 22 December 2014, 21:53:43 »
Ok it had a genuine cam sensor about 4 month ago, no codes shown up just the spanner light was flashing and cranking engine but not firing. Just driven it again and all is well.
could be pmt or the fact its christmas and as everyone knows cars always cost money at christmas ;D
« Reply #8 on: 22 December 2014, 21:54:53 »
Spanner light flashing is immobiliser.
Usually the immobiliser ECU cannot see a recognised transponder in the key
plym ian
  • Plymouth, Devon
« Reply #9 on: 22 December 2014, 22:01:08 »
just having a moment then :y
« Reply #10 on: 22 December 2014, 22:07:32 »
If it was just a one off, maybe.  Check the transponder in the key is secure, and stuck in place (a dob of superglue works).
plym ian
  • Plymouth, Devon
« Reply #11 on: 22 December 2014, 23:04:00 »
will do :y
