Author Topic: Scary - my life was relying on this! Dodgey MOT?  (Read 3074 times)
« on: 27 June 2008, 18:10:09 »
I knew I had a dodgey front brake disk on the GLS and I was getting a bit of judder when braking. It was in the back of my mind and I wasn't prepared to drive up to the Lakes without checking it out.
I just popped off the wheel and... I'm glad I did. I don't think I have ever seen a brake disk in such bad condition and frankly, I'm amazed it ever stopped.
This car has just passed an MOT. There is no way on the lords earth that this has deteriorated to this state within the last couple of weeks ::) So it raises question marks over the validity of the MOT  :o
Needless to say I've just changed them.
I recognise having done this there's no recourse or possibility of informing VOSA etc... but TBH our safety on the lakes run is more important :y
psychnurse
  • Leominster, Herefordshire
  • Whats in the fridge today? Beer and Sausages....UM
Re: Scary - my life was relying on this! Dodgey MOT?
« Reply #1 on: 27 June 2008, 18:14:05 »
 :o :o I have had some very dubious mot pases in the past. There was a guy locally who wa know for issuing dodgy mot's... not sure what happened to him but the garage closed about 3 yrs ago.
Glad you have stopping power!! Enjoy the lakes.... and pass my regards to all and inform them they MUST have a pint for me!!  :y
markey mark
  • SLady bitshorpe north lincs
« Reply #2 on: 27 June 2008, 19:59:00 »
remember a mot tester carnt remove the wheels and if the brakeing effiecncy is within tolernce he carnt fail them james can only test what he sees !! :-/
motmann
  • birmingham
« Reply #3 on: 27 June 2008, 20:02:40 »
sorry to hear your news james but things like this are far from uncommon, the one thing against us testers is if you carnt see an item your testing susch as pads,discs, shoes, wheel cylinders, brakepipes etc you must pass and advise. we are not even allowed to remove a hubcap!! many cars today from porsche to smart car have plastic covers on all of the undersides, if you cant see it you cant test it!! no exceuse for a worn brake disc on a miggie !!
theolodian
  • I need a new avatar.
« Reply #4 on: 27 June 2008, 20:08:27 »
My rear spring broke a few days after MOT.  He really should have warned me.  ::) ;D
« Reply #5 on: 27 June 2008, 20:12:34 »
So what you are saying then, is is I buy an old rotton 4x4 that has worked it's life on a farm by the coast.  Then I can build a full length underbody pan to cover up the rotton and corroded chassis and there aint a think you can do about it?
« Reply #6 on: 27 June 2008, 21:32:16 »
I agree for the most mate, but you could see even with the wheels on that these disks were absolutely shot - I  must post up some pics!
Taxi_Driver
« Reply #7 on: 27 June 2008, 21:48:47 »
Think i might have be inclined to pop it to an MOT station i was known at.......and asked them to test just the brakes.......with the reason 'it doesnt seem to stop in a straight line and was wondering if the brakes was causing it'.......would cost a few quid but you woulda known if the brakes passed or failed  ;)
The Elite
  • Herts
  • Fuel duty still sucks...
« Reply #8 on: 27 June 2008, 22:15:14 »
There is details on the back of your certificate on how to contact VOSA if you feel that the vehicle should not have passed, phone 0870 60 60440, this is valid for 28 days after the test, not sure what they would do if its after that.
Mig 3 coming soon.... Watch this space!
« Reply #9 on: 27 June 2008, 22:18:05 »
Give them a ring, they will send an inspector round to check them out with a "special brew" car for a test.
Taxi_Driver
« Reply #10 on: 27 June 2008, 22:53:41 »
 Bit difficult now.........as James has changed the disks himself....
« Reply #11 on: 27 June 2008, 23:33:35 »
Maybe so.  But if not reported then these things go by unnoticed and things carry on as they were.
stuart30
« Reply #12 on: 28 June 2008, 07:45:15 »
So what you are saying then, is is I buy an old rotten 4x4 that has worked it's life on a farm by the coast.  Then I can build a full length underbody pan to cover up the rotten and corroded chassis and there aint a think you can do about it?
Can only comment on experience and for me at least yes you can and i have (Unknowingly mind).
Basically bought an old Fiesta off a mate cheap (no MOT) had some remedial work done on it and whilst they were doing some bits and bobs they found a rotten section of flooring,welded (very very poorly) a plate and they took it for mot....failed on the plate (mot tester said he could have pulled it off with two fingers as it was just tacked on each corner of plate,so original guy who did the welding tacked it in a couple more places then painted some thick black type paint over it so it wasn't as visible and mot tester had no choice but pass it.....After when speaking to mot guy he said  it was a piss poor repair and id be better off scraping the car.
Most people assume if a car has a decent amount of mot it must be in fairly good health...maybe people put too much faith in a slip of paper. :-/
Allenm
  • Milton Keynes
« Reply #13 on: 28 June 2008, 10:55:08 »
Shouldn't you have noticed then?  ;)
JueV6
  • Kent
« Reply #14 on: 28 June 2008, 11:52:03 »
From what i remeber, Officially the MOT is only valid at the time of the test. ie you could theorectially drive out of an MOT station, and a brake pipe split or spring snap  after hitting a pothole in our wonderfully kept roads.
So although it's used as a roadworthy certificate for 12 months if a car fails the following year, WHEN did the suspect part fail. 1 week, 1 month, 6 months after.
I know general maintainence should pick up most faults. but some people do not take care of their cars.
