2.2 Head Gasket Fail?
Started by tunnie, 01 August 2006, 13:48:23
browsing fleabay, and seen the odd HG fail auctions on 2.2's?
Thought this would be very rare, they say suspected HG fail but what else could it be on a 2.2?
Seem to recall that some do have a small oil cooler near the oil filter...the 4 pots do very occasioanly suffer headgasket failure but, its easy enough to put right.
QuoteSeem to recall that some do have a small oil cooler near the oil filter...the 4 pots do very occasioanly suffer headgasket failure but, its easy enough to put right.
How much costs wise would i be looking at to repair a HG? 4 pot & v6?
If you have to pay a garage to do it, then you won't be making much money of it.
was thinking of doing it myself, getting along nicely with project A, hopefully it should be finished this weekend
You'll have to pop it round so I can have a look...
mar892ree
Mark the 2.2's have a heat exchanger on top of the oil filter housing sandwiched betwwen the filter housing and the oil pump
Mark
I thought they did, a 4 pot headgasket, about a ton with a head skim......plus cambelt, water pump and tensioers of course.
QuoteI thought they did, a 4 pot headgasket, about a ton with a head skim......plus cambelt, water pump and tensioers of course.
Humm ouch!! expensive then. Saw a 2.2 V plate 173k miles go for 300quid on fleabay.
not really worth it considering in all the costs..... and its end retail value.
Ah well just a possible thought, back to V6 projects!  :)
QuoteYou'll have to pop it round so I can have a look...
Yeah might very well do that at the weekend... i now have a flat stacker (like yours) for the oil change and coolant flush...
Since i have to flush mine anyway and yours needs doing as well, I could give you a hand at the weekend doing yours if you want? Not sure if there is a block in mine, fan cuts in at around 95 ish... got out of the car in a carpark and heard it going so i think its just crap coolant in it.
I am 90% sure now its the battery thats dead.... after another 30 min run the other day with my mum driving, i got back turned it off then tryed to start it again. All the lights lit up and so did the MID (though a little dim) turned the key, dead. no suprise there.
The following morning I had to move project A as it was blocking my dad in.... deceided to give it another try without jumping it, got in turned the ignition on. Nothing...... 2 extremely dim lights came on, oil an brake light i think, nothing else... MID dead. So i think the battery is not holding its charge.
selling a 173k 2.0l car would not be easy - many would be put off with that sort of miles...
