Author Topic: Heater Matrix Flush  (Read 1599 times)
Andy663
  • Ayrshire
    • 3.0 MV6 (2000)
Heater Matrix Flush
« on: 29 December 2014, 16:49:34 »
I've just had a look at the matrix flush, seems fairly straight forward. Will I lose any coolant when I disconnect the heater hoses?
4x4
Re: Heater Matrix Flush
« Reply #1 on: 29 December 2014, 16:54:33 »
Yes but why dont you change it whilst doing the flush.
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #2 on: 29 December 2014, 20:22:03 »
You'll lose a little when you disconnect the two hoses, but you'll lose everything that is in the Matrix.  I have no idea what volume the Matrix is, but as you will be bleeding the system anyway, it's certainly a good time to drain and replace as much coolant as possible (unless you have done so recently).
« Reply #3 on: 29 December 2014, 22:19:03 »
Not a lot in the matrix - its only small  ;)
