Author Topic: air vac pump  (Read 3621 times)
flyer 0712
air vac pump
« on: 02 January 2015, 22:44:11 »
Please can anyone tell me what the (air vac pump) that works the h.b.v. for the heater looks like....any pics or part number would help so that I can look it up....as try as I may I just cant find it on my 2.2 omega anywhere...looked by the pollen filter and tried to trace the air tubes but to no avail....so if I knew what it looked like I would know what I am looking for ..thanks.... :-\ :-[ :y
steve6367
Re: air vac pump
« Reply #1 on: 02 January 2015, 23:00:35 »
There is no pump, the vacuum is from the inlet manifold - rear bottom you will see a pipe connected. Behind the pollen filter is a vacuum tank.
Steve
  • Auckland
    • Mazda MPV
Re: air vac pump
« Reply #2 on: 03 January 2015, 10:29:07 »
Assuming that engine is petrol of course.
Diesel engines do need a pump which is often part of the alternator. Don't know what was fitted to the Omega 2.2 diesel :-\
steve6367
Re: air vac pump
« Reply #3 on: 03 January 2015, 10:31:47 »
Good point, I made a assumption is was 2.2 petrol - oops  :o
flyer 0712
Re: air vac pump
« Reply #4 on: 03 January 2015, 14:41:16 »
steve......andy...yes sorry it is a petrol 2.2....thank you for your help and i will investigate further  :y :y
Re: air vac pump
« Reply #5 on: 04 January 2015, 12:13:10 »
Check the vac guides written by MDTM.  They are for a V6, so ignore the multiram stuff, but the rest is the same :y
otomega25
  • Romania,Bucharest
    • Omega Caravan 2.2 DTi
Re: air vac pump
« Reply #6 on: 08 January 2015, 23:49:50 »
for information: omega 2.2 diesel has vacuum pump in head of camshaft, if engine is started she will produce vac
Re: air vac pump
« Reply #7 on: 09 January 2015, 00:05:05 »
As do most diesel powered cars... OPs car is petrol... vac comes from throttle body :y
