Author Topic: Indoor mobile phone signal.  (Read 1528 times)
tidla
  • solihull
« on: 04 January 2015, 16:32:03 »
Over the last few months i have been insulating the house using pir foam insulation which is backed with silver foil.
House is warmer, downside i think, is the poorer network signal. All the network sims i have tried generally give the same result.
Any remedies you know of??
moggy
  • hartlepool
    • vauxhall omega 3.0 elite
Re: Indoor mobile phone signal.
« Reply #1 on: 04 January 2015, 16:44:21 »
Our landlord did the same,just before we moved in.The house is lovely and warm,but we have the same problem.I don't know the fix,but i assume remove it. ::)
« Reply #2 on: 04 January 2015, 16:49:20 »
Yep, you've created a Faraday cage, I'm afraid.
http://en.wikipedia.org/wiki/Faraday_cage
tidla
  • solihull
« Reply #3 on: 04 January 2015, 16:54:38 »
You mean i can take my hat off?
« Reply #4 on: 04 January 2015, 17:02:44 »
Yep, but it won't cure you of being a radio amateur. ;) I've tried everything. ::)
    • 530D M Sport, 330i Coupe
« Reply #5 on: 04 January 2015, 17:26:29 »
I have an amp (*) for GSM and PCN frequencies which can help.
The idea was that it sat between a handset equipped with an antenna connector and an external antenna in a vehicle installation. It did actually improve things slightly in the early days of GSM.
(*) as it's 'technically' illegal to boost the signal, all this device actually did was cancel out the quite considerable losses in the coax cable.
