Author Topic: Auto to manual conversion - what needs to be updated with Tech2 ?  (Read 4351 times)
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
Happy New Year everyone.
I converted my MV6 from auto to manual in 2013 using the excellent guide put together by matchless.  The only minor issue I'm left with is the MID showing the "Automatic Gearbox" error on startup, can this be fixed with Tech2?
What else should/could be updated while the Tech2 is on it?
Cheers.
Re: Auto to manual conversion - what needs to be updated with Tech2 ?
« Reply #1 on: 04 January 2015, 17:41:53 »
MID reprogram.  Might be worth doing engine variant and ABS variant whilst there.
If you ever pass Hotel21's way, he could do it :y
sjc
  • Alloa, Scotland
« Reply #2 on: 04 January 2015, 17:47:03 »
Thanks TB, have you got the specifics mate?  I had a rendezvous with Hotel21 this afty but we couldn't figure it out between us, except we did manage to change the variant for the ABS/TC module.
If I go through the MID reprogram, does it give an obvious list to select from?
Cheers.
« Reply #3 on: 04 January 2015, 17:54:08 »
Can you press S and R together for 3 or 4 seconds, and check current config (one of the 3 digit numbers).
If its 048 (I suspect), change it to 046
Diagnostics > 1998 > Omega-B > Infotainment > Multi Info Display > Programming > Program Code Index and enter in correct number.
« Reply #4 on: 04 January 2015, 17:58:55 »
You could also remove the autobox wire from the MID plug, and tape it back into the loom... but that is a bit of a bodge ::)
« Reply #5 on: 04 January 2015, 18:07:44 »
Indeed, but given the OPs proximity to a Tech2, we'd go for the correct option :)
« Reply #6 on: 04 January 2015, 18:09:44 »
Quite right too ;)
sjc
  • Alloa, Scotland
« Reply #7 on: 04 January 2015, 19:08:16 »
Thanks for replies TB (& Al).
Pretty sure the current setting is 48, so will update that to 46.
The ABS module has been updated to "X 30 XE MT", anything else to be done?
hotel21
  • The Kingdom of Fife
« Reply #8 on: 05 January 2015, 13:41:19 »
The numbers shown were 48 and 3. Didn't know code options so left it meantime and suggested contacting either TB or Omegatoy.  :)
« Reply #9 on: 05 January 2015, 17:29:05 »
48
Code Index - this needs changing via method I posted earlier
3
Changing Code Index will put latest code version on, no choice.
sjc
  • Alloa, Scotland
« Reply #10 on: 05 January 2015, 20:43:06 »
Updated to 46 and 'Automatic Gearbox' message is now gone.   :y
Thank you TheBoy and hotel21.
Now, if only Tech 2 could fix a (very probable) failed head gasket  :'(
« Reply #11 on: 05 January 2015, 20:44:50 »
Oh crikey, not yours as well?
Symptoms?
sjc
  • Alloa, Scotland
« Reply #12 on: 05 January 2015, 21:00:00 »
Pressurised cooling system, runs rough on startup if pressure not released soon after last run  :(
After discussing with Broocie, gonna pull the plugs out to see if any are super-clean, will also use my coolant system pressure tester to see if any water shows up in the cylinders.
No excessive steam from exhaust yet, so must be early stages.  System only pressurises when giving it some, if driven lightly it's ok - pity I never drive it lightly  :P
Who else is having troubles?
« Reply #13 on: 05 January 2015, 21:01:49 »
That's not a common failure mode of GM V6 head gaskets. Which are normally bulletproof to start with...
sjc
  • Alloa, Scotland
« Reply #14 on: 05 January 2015, 21:09:36 »
I must have a talent then :)  Cavalier 1.8 SRi: HGF at 100k (first sign, blown top rad hose), Carlton 2.0L: HGF at 100k (first sign, pressure relief cap), Omega 3L V6: F1-style HGF at 160k (first sign, pressure relief cap), now another Omega 3L V6 with the same pressurised coolant system.
Maybe I should stop chipping them and raising the rev limit  ::)
