Author Topic: Power steering fluid - Dex VI?  (Read 1459 times)
rollacorolla
« on: 05 January 2015, 19:15:37 »
Hi all,
Having read the posts about problems with using Dex III for power steering fluid and that Dex II should be used, Burnham Garage told me Dex VI is now what is being used for Vauxhall power steering and has replaced Dex II. Will this be ok or will I have problems with leaks like with Dex III?
Cheers.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Power steering fluid - Dex VI?
« Reply #1 on: 05 January 2015, 20:06:49 »
The reason, dex2 is specified, and recommended by GM and us,is anything above dex2 causes leaks in the pas system,mainly around the rubber hoses.
Hoof'land storeman.
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #2 on: 05 January 2015, 20:08:41 »
That's veeeeeeeeerry interesting. my pas fluid seems to leak. just checked and it is dexIII I been putting in  :'( :'( :'(
RIP Paul Lovejoy
« Reply #3 on: 05 January 2015, 20:26:28 »
DEXVI is NOT suitable....on DEXII will do
rollacorolla
« Reply #4 on: 05 January 2015, 21:37:55 »
Ok thanks guys. I found 1L Fuchs Titan ATF 3000 on Amazon which is Dex II certified so will go with that.
