mobile phone contacts swap
Started by tidla, 07 January 2015, 09:36:52
tidla
Is there a simple tool out there for swapping contacts from samsung to sony?
zirk
If the Samsung is Android try 'My Phone Explorer' Software  :y
http://www.fjsoft.at/en/downloads.php
henryd
Quote from: tidla on 07 January 2015, 09:36:52
do you have a gmail account?,if so its simple :y
other rides
Terbs
Kids brought me a Luminaire 530 for Christmas....I am on 02. Went online to switch sims and balance, contacts, etc...but it did not swap contacts as they were stored on a HD or Card. Does that make sense.
Son in law did it fast manually. I assume they were stored in a folder and it had to be transferred via the PC. :y
Bit of info if you get a problem :y
4x4
Save contacts to sim on old phone,then swap sim to new phone and load contacts.
The Sheriff
Quote from: 4x4 on 07 January 2015, 14:05:00
A Lot of older phones have the old, big sims. New phones have the awkward, fiddly smaller ones.
Terbs
Quote from: STMO on 07 January 2015, 15:29:18
Yes ....that was the problem I had
tidla
Quote from: henryd on 07 January 2015, 12:03:33
Google knows too much as it is..
AndyRoid
Create a Gmail account, sync your current contacts on the old phone, then import them on the new phone using the same Gmail account.
If you prefer a software solution due to Google knowing too much already, use Super Backup
omegod
Quote from: terbert on 07 January 2015, 15:47:55
you can cut them down easily
Terbs
Quote from: omegod on 07 January 2015, 22:08:50
Can you really ? That's worth remembering :y
Arse backwards... ::)
New, mini sim inserted into old phone with use of a cage... contacts onto small sim... small sim out of cage and into new phone... transfer sim contents to new phone... job jobbed :y
AndyRoid
Quote from: Taxi Al on 07 January 2015, 22:50:05
That's fine if your contacts consist of just a name (with limited characters) and number, but that is all a SIM will hold.
Extra info (such as address, e-mail addy, etc) will only be stored in the handset (or Google cloud) itself.
Quote from: AndyRoid on 08 January 2015, 10:31:04
Fair point, well presented  :y
tidla
Thanks for the help.
Gmail seems the way to go, and yes there's more than just names and numbers. :y
