Author Topic: wheel bearing cost estimate  (Read 4908 times)
firemoth
  • Preston, Lancashire
    • Vauxhall omega 2.2dti est
« on: 10 January 2015, 17:48:31 »
Hi. Hot a noisy wheel bearing n/s/r on a 2001 estate DTI. Do anyone know a rough price it should be? Been quoted £175 which seems very high. Last one I had done (rover 400, same wheel) was £80. If anyone has any real life figures for theirs being done it would be helpful too.
Thanks
Re: wheel bearing cost estimate
« Reply #1 on: 10 January 2015, 17:53:42 »
Hub needs stripping to remove it... so disc, caliper and drive shaft all need removing, then hub itself needs pulling out, then you have to persuade the bearing out...
Estate bearings are different to saloon ones too, so buy carefully. £175 sounds alot, but depends on the labour rate... it could take two hours, or it could take all day... :-\
Bearing kit should be about £30...
firemoth
« Reply #2 on: 10 January 2015, 18:35:21 »
Is anything on these things simple?  :( >:(
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #3 on: 10 January 2015, 19:12:23 »
removing the hub is the bit that causes grief, I struggled with mine until I made a specific puller.
The bearing itself is easily removed/replaced with same kit that is used to do FWD cars without removing the strut. Any garage will have suitable kit for that.
£175 is actually a pretty reasonable price all things considered. Make sure that's a firm price though, as they might struggle!
« Reply #4 on: 10 January 2015, 22:36:51 »
No.  ;D
firemoth
« Reply #5 on: 11 January 2015, 00:16:22 »
No.  ;D
There goes my glimmer of hope......  :-\
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #6 on: 11 January 2015, 10:11:51 »
VX bearings were £34.67 +VAT on TC last Sept., and I paid my local indy £40 each to fit, so less than half your quote. :y
« Reply #7 on: 11 January 2015, 10:45:33 »
:o
Bet he won't do the next one for £40 What's his number? :y
Shackeng
  • Ramsbury
« Reply #8 on: 11 January 2015, 11:13:17 »
:o
 :-[ :-[ :-[ :-[ Ooops, sorry, just checked, it was £60 (+VAT ::)), still good value I think. The same guy just re-gassed my AC, properly, for £35. :y
He also recently pressed in two new rear W/B bushes for nowt. :y
« Last Edit: 11 January 2015, 11:15:07 by Shackeng »
firemoth
« Reply #9 on: 11 January 2015, 11:18:37 »
:o
Where is this fella? That price makes things more viable :)
Shackeng
  • Ramsbury
« Reply #10 on: 11 January 2015, 11:40:32 »
:o
Probably too far for you, its in Wiltshire! :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #11 on: 11 January 2015, 12:54:21 »
Dont tell Entwood :y
« Reply #12 on: 11 January 2015, 13:44:15 »
Why not ??  Mine was done by Sassenach in Trowbridge for the cost of the bearing and in 1 hour 40 minutes !! Great shame he no longer frequents the forum as he had a great deal of knowledge and some amazing home-built tools, as well as being an extremely helpful and friendly person.
http://www.omegaowners.com/forum/index.php?topic=102254.40
Post number #40
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #13 on: 11 January 2015, 14:32:11 »
Just knew you were in Witshire. Read your old post.Fantastic what other members will do to help. My daughter lives in Chippenham so we might run into each other sometime.Not in our cars hopefully. :y
firemoth
« Reply #14 on: 11 January 2015, 15:26:20 »
That's a shame. Well if there's anyone up Lancashire way that does DIY mechanics and fancies some extra pocket money feel free to let me know....
