Author Topic: What would a pair of Bill Blydenstein 3L V6 heads be worth  (Read 8924 times)
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
I'll shortly be selling my '99 3L MV6 manual which has been tweaked a little - Bill Blydenstein heads, 3.2 manifolds, Jetex exhaust, Red Dot Racing chip, AC/EGR/SAI removed, Eibach springs, Bilstein shocks, Irmscher front bumper, rear bumber dechromed and fully painted.  Also has Elite interior with Bose and rear blind.
Sad thing is, I suspect it will be worth more broken than as a full car.
I have a fair idea what most parts would fetch but have never seen another pair of Bill Blydenstein heads being traded.  Anyone have a feeling for what they'd be worth?
Cheers.
Varche
  • middle of Andalucia
    • Golf Estate
Re: What would a pair of Bill Blydenstein 3L V6 heads be worth
« Reply #1 on: 11 January 2015, 17:53:22 »
No idea, never seen them come up before. What performance increase are they supposed to give?
It seems a shame to break up a running car but it wouldn't be the first time.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 11 January 2015, 18:16:25 »
Think somebody took the company over,and it lost its way after then.Blydenstien died in 2006.
As others said its worth more as a sum of its parts.
Hoof'land storeman.
sjc
  • Alloa, Scotland
« Reply #3 on: 11 January 2015, 18:45:48 »
Pulls like a train from 4k upwards - I'd say an extra 25bhp from the heads and maybe another 15-20bhp combined from the 3.2 manifolds, Jetex exhaust and Red Dot chip.  Must get it rolling roaded soon.
biggriffin
« Reply #4 on: 11 January 2015, 20:24:47 »
With that work done might be 30hp extra at flywheel, the heads and exhaust side help it flow better,so its working more effectively,
Hoof'land storeman.
« Reply #5 on: 12 January 2015, 08:15:25 »
Dream on!
You may get up to 10bhp more from ported heads....its the exhaust manifolds that are the issue.
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #6 on: 12 January 2015, 09:25:40 »
Can you tell us is this was 'breathed on' by the man himself at the helm? (ie: before/after his death in 2006) Even if it doesn't offer that much in power, it's got kudos in the 'collectablility' for a Vauxhall nut  :)
Cheers  :)
sjc
  • Alloa, Scotland
« Reply #7 on: 13 January 2015, 07:14:33 »
Mark - I can dream can't I  ;D
DBG - these were done in 1999, definitely by the man himself, the engine is from a '95 Manual Elite (retail, not plod) owned at the time by ABS member Graham Morris.
« Reply #8 on: 13 January 2015, 09:23:25 »
Thanks for the reply sjc. Ok -
so... (and this question is open to all OOFers to reply to, really, as well as the seller) what is the difference with these heads, over a normal 3litre V6?
and Mr DTM - is it right, then, that 3.2 manifolds are giving extra breathing and the extra oomph in this case? If one understands his basic engine design correctly, ported heads plus larger manifold = easier breathing. Easier breathing = not massively more power per se, but an engine with an easier driving nature.
Is any of this compatible with/waste of time fitting to a 2.5 V6? (which at some point will get fitted with G cams as well)
Thanks!  :y
« Reply #9 on: 13 January 2015, 10:07:26 »
Reality is that the head design on the Ecotec is pretty good out the box (true of most modern head designs).
All you can do is match the inlets to the heads and flow the inlets a little plus remove any casting flash around where the valve seats are. Little you can do to the valve guides as they are already bulleted and recessed (messing with these will result in heat issues with the exhaust valve and probably more valve wander and guide wear).
Exhaust ports you can flow a bit but again, there not bad, same approach as the inlets actually.
2.6/3.2 manifolds are far better than the 2.5/3.0 (they are pressed steel and not cast, larger capacity and much much smoother), there not up to tubular manifold territory but are a good off the shelf upgrade for not silly money.
To do anything more on the heads would require custom inlet manifolds and larger valves, on the Ecotec larger valves are a challenge as you either end up with small seats (not good, again from an exhaust valve heat perspective) or a shed load of work to fit new seats and lots of head machining.
Its the old basics, get more air in (which the above does) allows more fuel to be added which gives more power and allow the exhaust gas to flow out easier (reduced losses) and you can get better cylinder scavenging.
« Last Edit: 13 January 2015, 10:09:04 by Marks DTM Calib »
« Reply #10 on: 13 January 2015, 10:31:33 »
Much appreciated. So as per you earlier post, the heads are giving you a teeny bit, the manifolds from a 2.6/3.2 are giving you a bit more.
Just to confirm, when you say "2.6/3.2 manifolds are far better than the 2.5/3.0" we're talking exhaust manifolds, yes?
Sorry to throw another question at you Mark, I'm just eager to know as much as poss about the V6, and always happy when I realise there's more to learn!  :y
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #11 on: 13 January 2015, 11:07:33 »
I fitted 3.2 manifolds as part of my head gasket job last year. As Mark said the port work that is simple and worthwhile on older engines -like blending in bored holes or tapering the valve guides - is already done and the manifolds fitted so well I couldn't see the point.
With no other changes, it picks up noticeably better at 3000rpm, and revs quicker round to the redline. On the rare occasions I drive it that hard!
Definately a worthwhile mod, especially if you get a good price on the manifolds. Bear in mind that you must use the matching gaskets, which are quite expensive.  I'm not sure I'd like to do the job with the heads still on the car though.
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
« Reply #12 on: 13 January 2015, 18:31:32 »
That was going to be my question...how hard is it to change the manifolds with the heads still on?
« Reply #13 on: 13 January 2015, 18:42:06 »
If you go by the name of MDTM, easy. For mortals, challenging
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #14 on: 13 January 2015, 19:13:39 »
True that.
RIP Paul Lovejoy
