Author Topic: Rear wheel bearing cost ?  (Read 1810 times)
« on: 12 January 2015, 22:37:22 »
Anyone know if its a big job to replace both rear wheel bearings on a Jeep Cherokee  :-\ Dont mind it going to a garage to get them replaced but guessing its not an easy job to diy  :-\
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Rear wheel bearing cost ?
« Reply #1 on: 12 January 2015, 22:42:53 »
They use a live axle, so it shouldn't be too bad: remove the brake, undo the backing plate, use a slidehammer to pull the halfshaft, drill/grind the retaining collar so the bearing can come off, and then have the new bearing/collar pressed back on. You will need the press, although anyone who has one is likely to do this job for a drink as it's a quick easy job.
« Reply #2 on: 12 January 2015, 22:49:09 »
Thanks nick , not sure im up to doing that myself but sure serek would be up for it  ;)
  • Chatham, Kent
« Reply #3 on: 12 January 2015, 23:01:28 »
I should clarify, it's the pressing the new bearing that is a drink, not the whole job!
« Reply #4 on: 12 January 2015, 23:02:59 »
Bah... if you can hear the wheel bearings over diff whine, then you've bigger issues... ;D
« Reply #5 on: 12 January 2015, 23:03:54 »
Can't be more than eight bolts holding the axle on :-\
« Reply #6 on: 12 January 2015, 23:10:54 »
Going to have a look/listen first  :)
  • Chatham, Kent
« Reply #7 on: 12 January 2015, 23:16:56 »
It's too bloody heavy to remove the entire axle from the car just to change a wheel bearing! Makes it harder to pull the halfshaft too. Learnt all that with a Capri axle, which is probably half the weight of a Dana.
