Tablet internet ?
Started by omega3000, 15 January 2015, 16:50:15
ckz
What you want is an I pad, tab s or similar.
Anything with simcard.
I'm using since years the ipad, even with mount in the car as ats nav,
SIM card based.
But switches over to wifi if in range.
After the update last year it stoppt working on sim, apparently can't read the sim, loads of rubbish as it allways worked and around 6k of pads had the same problem after the update.
Short story I got a tab s which is same size and is doing the same, may even more.
Batterie life is a bit shorter but works.
Again SIM card based.
Works for me.
Mr.OmegaMan
If you can't use your phone to 'Hot Spot'
This might be the simplest dilution.
These two will do the job nicely, (Just make sure you have decent EE signal in the areas you wish to use)
The EE Sim with 6GB is good for 3 months unless you use the 6GB allowance up first which is unlikely unless you are going to watch a lot of streaming content. Should be fine for normal browsing.
EE Sim
http://pages.ebay.com/link/?nav=item.view&alt=web&id=331188493836
MiFi
http://www.amazon.co.uk/dp/B00KR51QCO/ref=cm_sw_r_awd_UtvUub1RZRBWS
HTH :)
Mr.OmegaMan
Just seen this, Seems a good deal if you don't mind contracts :y
http://bit.ly/1FDfKjF
AndyRoid
Quote from: Mr.OmegaMan on 16 January 2015, 18:18:39
If you can't use your phone to 'Hot Spot'....
The phone certainly has the ability to do it, it's down to the service provider whether you actually can or not (or rather, the T&C's of the contract you have with the service provider).
For example, new customers on the 3 network with an "all you can eat" contract cannot tether however they can download as much as they like on the handset itself.
Virgin phone contract  :)
Mr.OmegaMan
What I meant by if you can use your phone as a hot spot was if that feature is available on that device as I don't know what phone EMD has could be a Nokia 3310 for all I know  ;D
I'm with THREE pay as you go and buy the 15 all in one package which comes with unlimited data, It doesn't include teathering although I've teathered 100s of GB of data using iPhones. Anywhere up to 20mbps download, 2.5mbps upload.
ckz
iam with 3 on my s4 and i have everything i need on.
all you can eat data etc
no probs at all
can create hot spot etc.
the tab s is on 3 contract and can also be used as phone in the car mainly if need over the stereo.
both on contract.
workphone is on ee and is a blackberry.
very limited to the s4 and signal is poor compare to 3.
thats at least my experience.
iam with 3 for now 9 years.
never had any problems.
Quote from: STMO on 16 January 2015, 17:59:58
I reckon you could mess about and jump through hoops and then find you dontyreally need it anyway.
Exactly. Last time I used my mifi was in Cyprus last year. I suspect the next time will be Cyprus this year.
Quote from: Emd on 16 January 2015, 22:38:34
What handset?
Does the contract have a data allowance?
I assume you're happy with EE's (virgin use EE's 2g/3g (only, not 4g)) data coverage?
AndyRoid
Quote from: Mr.OmegaMan on 16 January 2015, 22:39:39
Good point, I assumed it was a smartphone as pretty much everybody has one these days.
Quote from: ckz on 16 January 2015, 23:11:45
That will be why then, the tethering ban on the all you can eat package only applies to new customers.
Mr.OmegaMan
about 4 years herewith THREE although I do use EE now and then for the MiFi if/when required  :y
Quote from: TheBoy on 17 January 2015, 10:02:01
What handset?
Samsung Galaxy Ace
Data allowance yes
3G
AndyRoid
Quote from: Emd on 17 January 2015, 19:26:42
Samsung Galaxy Ace
Data allowance yes
3G
Yes that handset allows you to turn it in to a Wi-Fi hotspot, and yes Virgin do allow tethering.
Use 2 fingers to pull the "drop down bar" (aka Quick Access panel) down from the top and you will have ALL the quick access buttons available.
Select the Wi-Fi Hotspot button (with your data enabled of course), and you will then see a page that gives you the hotspot name (which is AndroidAP by default) and the password it wants you to use to access the hotspot (you may change both if you wish).
Quote from: AndyRoid on 17 January 2015, 19:45:04
Samsung Galaxy Ace
Data allowance yes
3G
Ok thanks , ill give that a go  :y
