Author Topic: Temperature Guage  (Read 3296 times)
rikki_essex
  • essex
    • 2L gls estate with lpg 20
Temperature Guage
« on: 16 January 2015, 23:09:33 »
Just a little niggle the engine temperature gauge doesn't work or i should say ive only seen it work on a couple of occasion any ideas? Most of the time it just sits on the bottom of the gauge and doesnt move at all.
regards Rik
Re: Temperature Guage
« Reply #1 on: 16 January 2015, 23:12:16 »
Loose connection on the sender ?? They are only push on spade connections.. :(
rikki_essex
  • essex
« Reply #2 on: 16 January 2015, 23:21:53 »
ok thank you i shall look into that tomorrow sorry to be a pain but where is the sensor located
regards Rik
« Reply #3 on: 16 January 2015, 23:33:31 »
In the V at the back  ;)
« Reply #4 on: 16 January 2015, 23:37:33 »
2ltr V6? Interesting!  :D  ;) or maybe a V4?  :-\  ;D
« Reply #5 on: 16 January 2015, 23:42:43 »
opps sorry ill get me coat  :-[
« Last Edit: 16 January 2015, 23:51:01 by Emd »
« Reply #6 on: 17 January 2015, 00:45:13 »
As you redeemed yourself Mr Emd, you are forgiven!  :y
« Reply #7 on: 17 January 2015, 09:17:14 »
When you find the sensor as per picture, you can prove the gauge by grounding the blue wire from it. The gauge should then read fully hot.  :y But it's likely to be as suggested, an iffy connection.  ;)
« Reply #8 on: 17 January 2015, 10:38:00 »
Other times this happens is if the instrument panel has partially popped off its connector. Flat hand on rev counter, gently, but sharply push, you'll feel it reseat if that is the issue.
