Author Topic: 6 cylinder lpg  (Read 5736 times)
EMD
  • Noofhampton
    • 95t
6 cylinder lpg
« on: 23 January 2015, 16:17:22 »
Has anyone got a recommended lpg installer to use ? Any price guide to a V6  :-\ Gas tank can be slung underneath , looking at a big tank , not sure of sizes but it will go under the boot on the truck   :y
Omegatitis
EMD
  • Noofhampton
    • 95t
Re: 6 cylinder lpg
« Reply #1 on: 23 January 2015, 16:33:41 »
Or could possibly have a go at home fitment
lpg kit
Omegatitis
Re: 6 cylinder lpg
« Reply #2 on: 23 January 2015, 16:48:52 »
That evapourator would barely run a decent fiesta engine.
Yet another clear example of why egay should be avoided.
Re: 6 cylinder lpg
« Reply #3 on: 23 January 2015, 16:52:24 »
A stag kit, so familiar ground to plenty on here. :y
Not sure what current prices are like, but that strikes me a pricy for the front end bits only excluding any consumables, so you will need nozzles, hose and clips, all mounting and plumbing hardware, a programming cable, some polyflex hose to the rear, tank, valve and valve box, tank mounting hardware, filler and so on.
EMD
  • Noofhampton
    • 95t
Re: 6 cylinder lpg
« Reply #4 on: 23 January 2015, 16:55:10 »
Is it Lazydocker that fits them  :-\
Omegatitis
Re: 6 cylinder lpg
« Reply #5 on: 23 January 2015, 17:01:21 »
His contact no longer supplies stuff.
EMD
  • Noofhampton
    • 95t
Re: 6 cylinder lpg
« Reply #6 on: 23 January 2015, 17:03:06 »
Damn  :(
Omegatitis
4x4
Re: 6 cylinder lpg
« Reply #7 on: 23 January 2015, 17:08:07 »
Theres a place in corby that installs lpg and also finedon  :y
EMD
  • Noofhampton
    • 95t
Re: 6 cylinder lpg
« Reply #8 on: 23 January 2015, 17:09:58 »
Contacted the one in corby mate , no response and estimated cost from their website is between £1100-1400 i think  :-\
« Last Edit: 23 January 2015, 17:11:37 by EMD »
Omegatitis
Re: 6 cylinder lpg
« Reply #9 on: 23 January 2015, 17:16:26 »
Prins prices. From £1680/£2100 inc VAT depending on the system you go for.  ;)  So assuming Prins will be the most expensive, you can work downwards from there for a fully installed system.  :)
http://www.prinsautogasuk.co.uk/conversion-price-list.php
Re: 6 cylinder lpg
« Reply #10 on: 23 January 2015, 17:19:21 »
And I'd be happy to pay a small premium for PRINS, as it is a better system
EMD
  • Noofhampton
    • 95t
Re: 6 cylinder lpg
« Reply #11 on: 23 January 2015, 17:22:35 »
Thanks tig , quite a low warranty considering , is that valvecare worth the extra  :-\
Omegatitis
Re: 6 cylinder lpg
« Reply #12 on: 23 January 2015, 17:32:34 »
Mine has a Prins VSI system which was installed at 56000 ish miles and I've just taken her through 230,000 miles.  8)  No valvecare on it either.  ;)
Any problems I've had with it have been related to general engine problems such as coolant leaks, rather than the LPG system itself.  :y
So I'd say it's a good advert for Prins!  Maybe I should contact them and they'll give me a large cash reward!  ::)  ;D
Re: 6 cylinder lpg
« Reply #13 on: 23 January 2015, 17:36:38 »
Valvecare/flashlube is only required if the valves are too hard in the head. GM V6 doesn't need it.
4x4
Re: 6 cylinder lpg
« Reply #14 on: 23 January 2015, 17:38:20 »
Not a gm engine but isuzu  ;D
