Pages: [1] 2 3  All   Go Down
Author Topic: Parts  (Read 8288 times)
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Parts
« on: 23 January 2015, 20:59:51 »
1..Been driving it round town and temp gauge seems lower than the 2.2 and temp not as good.. Then i hit the motorway today and down the needle came to the bottom.. So feel sure thats thermostat jammed open.....Am i Right ?
2..Also Got to get the cam belt done on this.
Where from, and which ones do i get..
Do i need anything else with thermostat..
is it belt tensioners pulleys etc   TIA
Do i get water pump although the timing belt dont drive it like the 2.2 (I Think)
EMD
  • Noofhampton
    • 95t
Re: Parts
« Reply #1 on: 23 January 2015, 22:38:17 »
You dont need to change the water pump but if it was me i would .. sounds like your stat and you want the tranfer pipe an housing . Full timing kit inc belt .
Omegatitis
Steve B
  • Leicestershire
Re: Parts
« Reply #2 on: 23 January 2015, 23:31:38 »
ok seen the transfer pipe pics with its 2 .O. rings.. Also need to no where to get that from  :-\ :-\
I think i should go on the assumption that the pumps never been changed...is 75 000 time to change then  :-\
« Last Edit: 23 January 2015, 23:43:40 by BIGtime »
Re: Parts
« Reply #3 on: 24 January 2015, 00:28:53 »
Makes sense to do it all while you're there :y
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
Re: Parts
« Reply #4 on: 24 January 2015, 00:36:29 »
Doing mine this weekend. Got all the parts from the dealers on trade club, still a big bill  :'( By Wednesday this week I hope to have it all done then I can go out and play.
cam belt
water pump
wishbones (with poly's)
track rods
steering idler
drop links
rear discs and pads
breathers
cam cover gasket on 246  :o
« Last Edit: 24 January 2015, 00:39:30 by joff »
Steve B
  • Leicestershire
Re: Parts
« Reply #5 on: 24 January 2015, 00:42:54 »
meaning pump too Al  :-\
Steve B
  • Leicestershire
Re: Parts
« Reply #6 on: 24 January 2015, 00:47:03 »
cam belt
water pump
track rods
steering idler
drop links
rear discs and pads
breathers
Shut up  ;D ;D ;D ive got enough to think about......its a new path of thought when you move over,... thermostat used to be 2 bolts a stat a gasket and some red glug .not now.. its a bleeding day job  ;D ;D ;D
joff
  • swindon, wilts
  • Discovery TD5 ES
Re: Parts
« Reply #7 on: 24 January 2015, 00:49:52 »
cam belt
water pump
track rods
steering idler
drop links
rear discs and pads
breathers
Oh for the love of Omega's
Re: Parts
« Reply #8 on: 24 January 2015, 00:50:34 »
.... thermostat used to be 2 bolts a stat a gasket and some red glug .not now.. its a bleeding day job  ;D ;D ;D
I had a 1700 diseasal Astra, and its thermostat was a 20 min job including boiling the kettle for a brew ........ I've no idea where my Merc's thermostat is  :-[
Steve B
  • Leicestershire
Re: Parts
« Reply #9 on: 24 January 2015, 01:01:24 »
cam belt
water pump
track rods
steering idler
drop links
rear discs and pads
breathers
Just come up with a great idea  :D :D I could come to your house and you can do them together  ;D ;D
Steve B
  • Leicestershire
Re: Parts
« Reply #10 on: 24 January 2015, 01:03:38 »
i remember the black and white days too Andy...... 3 bolts and your starter moter and bendix hit the kurbside.. ;D ;D
Re: Parts
« Reply #11 on: 24 January 2015, 01:07:18 »
My 1700 diesel Astra wasn't that long ago  ;) .... but I know what you mean  :y
Re: Parts
« Reply #12 on: 24 January 2015, 01:15:06 »
Indeed. Especially as the car is new to you...as Joff will testify, do it all once and not worry about it :y
Re: Parts
« Reply #13 on: 24 January 2015, 09:05:18 »
You do really. Like all Merc owners, you know its under that large metal panel that extends from the windscreen forward to the headlights...  ...that access panel that nice man in Mercedes Benz overalls uses to "do things".
Re: Parts
« Reply #14 on: 24 January 2015, 09:25:26 »
I've never looked for it ......  and mine is a plastic panel  ;) As for Merc overalls.......... I'm not paying £100+ an hour labour rates when there are independants out there  :y
Pages: [1] 2 3  All   Go Up
