Author Topic: Few more problems  (Read 1044 times)
Omega4117
  • Northern Ireland
    • Omega 3.2 V6 Elite
Few more problems
« on: 01 February 2015, 06:56:24 »
One other thing i meant to mention was:
The car was driving fine, has been using oil or water and reasonably economic until one evening she through up the engine management light and completely died. Felt like a mis fire and after i through it onto dignostics came up misfire on 2,4,6. I went for a wee hoak, pulled the sparks from 135 to find the had a bit of oil on them, pulled 246 out and they were completly soaked in oil and oil had created a pool inside the plug well. all were oil except for 6 which was oil and water more water than oil tbh. Cleaned it out n replaced sparks n that solved it but from then she drives fine but now hittin 90 n fan having to come on to drop her away down again but not under hard driving just general 30 -40  n now a nice cloud of white smoke following me everywhere. I was thinking cam cover gaskets for the oil but now wondering are the heads starting with her over heatin n blowing smoke. water level hasn't dropped very much. half a mill maybe n the tiniest amount of mayo on the oil cap which i thought was maybe just a tiny bit on condensation. Any ideas? Am i on the right track or is there any else i need to check for.
Thanks
Re: Few more problems
« Reply #1 on: 01 February 2015, 07:01:38 »
Misfire is oil in plug wells... replace camcover gaskets and clean the breathers as per guides.
Water in plug wells points to leaking scuttle... remove, clean and refit as per guides.
Mayo on oil cap normal with crap oil/short journeys.
Smoke is probably oil burning off... if the plug wells are full, then chances are oil is also dropping onto the exhaust.
Read here... http://www.omegaowners.com/forum/index.php?topic=90633.0 for most issues :y
