Author Topic: Code Reader logs  (Read 1524 times)
asiza
  • isreal
    • omega b 2.5
Code Reader logs
« on: 14 February 2015, 22:01:47 »
hello to all
my car drink too much fuel , something around 5 l/h
i took a logs from my 2.5 1998 omega with Code Reader and i don't know if the value that i receive is o.k.
if some of you know how to read it or if you know about a link with explanation i wold like  to know.
the log that i receive is:
Identifier                      0D
Battery Voltage            13.7 V
Immobiliser Signal   Received
Immobiliser           Active
TPS Signal (Throttle Position Sensor)   0.57 V
Simulated Idle Position   Active
Simulated Full Load Switch   Inactive
Mass Air Flow Sensor   0.95 V
Mass Air Flow Sensor   21 kg/h
Coolant Temperature   1.72 V
Coolant Temperature   64 °C
Intake Air Temperature   3.29 V
Intake Air Temperature    26 °C
Engine Type           6 Cylinder
Transmission Coding   Automatic Transmission
Park/Neutral Switch   P - N  0V
A/C Information Switch (Air Conditioning)    Inactive 0V
A/C Compressor Switch (Air Conditioning)   Inactive 0V
Telltale (Check Light)   Off 12V
Fuel Pump Relay   Active 0V
Spark Angle before TDC (Top Dead Centre)   -3 °CA
Ignition Coil Cyl. 1+4 (Cylinder)   Load
Ignition Coil Cyl. 2+5                  Spark
Ignition Coil Cyl. 3+6 (Cylinder)   Load
Knock Signal   Inactive
Knock Retard   0 °CA
Secondary Air Pump Relay   Inactive 12V
EGR Valve (Exhaust-Gas Recirculation)   Inactive
EGR Position Feedback (Exhaust Gas Recirculation)   0.74 V
Fuel Tank Ventilation Valve   0%
O2 Sensor 1   615 mV
O2 Sensor 2   254 mV
O2 Sensor Loop 1   Closed
O2 Sensor Loop 2   Closed
Air/Fuel Ratio 1   Lean
Air/Fuel Ratio 2   Rich
O2-Loop 1 Integrator   137 Steps
O2-Loop 2 Integrator   135
O2-Loop 1 BLM Idle (Block Learn Map)   170 Steps
O2-Loop 2 BLM Idle (Block Learn Map)   98 Steps
O2-Loop 1 BLM Partial Load (Block Learn Map)   102 Steps
O2-Loop 2 BLM Partial Load(Block Learn Map)   102 Steps
Hall Sensor   Inactive
Engine Speed Pulse   Inactive
Engine Speed   693 RPM
Idle Air Control   138 Steps
IAC Integrator (Idle Air Control)   135 Steps
IAC Adaptation Slope (Idle Air Control)   144 Steps
IAC Block Learn (Idle Air Control)   130 Steps
Desired Idle Air   17 kg/h
Actual Value Idle Air   17 kg/h
Desired Engine Idle Speed   710 RPM
Injection Pulse   3.8 ms
Engine Load Signal   1.6 ms
TPS Load Signal (Throttle Position Sensor)   0%
Vehicle Speed Pulse   Not Received 12V
Vehicle Speed   0 km/h
Intake Manifold Valve 1   Inactive 12V
Intake Manifold Valve 2   Inactive 12V
Torque Control   Inactive
A/C Cutoff Relay (Air Conditioning)   Inactive 12V
Diagnostic Request   Inactive 5V
best regards
asi
« Last Edit: 14 February 2015, 22:06:13 by asiza »
Re: Code Reader logs
« Reply #1 on: 14 February 2015, 23:03:38 »
Was it fully warmed up when you took those readings? Coolant temperature is rather low, suggesting the thermostat might be bad. If not, let it warm up fully and see what it's like then. :y
