Author Topic: Knock Sensor  (Read 2594 times)
Knock Sensor
« on: 16 February 2015, 14:49:03 »
Where is the offside one?  The cable disappears over the top of the alternator...  ::)
When I reassembled after changing the headgaskets I didn't route the cable properly and it was rubbing on the auxbelt, so yesterday I tried tucking it up behind the tensioner and it's caught and snapped!  :(  :(  :(
I'm guessing it's a complete basteward to change?  ::)  :'(
Re: Knock Sensor
« Reply #1 on: 16 February 2015, 15:28:39 »
Re: Knock Sensor
« Reply #2 on: 16 February 2015, 15:39:50 »
Is that underneath the exhaust manifold Rob?  :-\
Have you got one by any chance?  ???  :-*
« Last Edit: 16 February 2015, 15:41:33 by Sir Tigger »
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Knock Sensor
« Reply #3 on: 16 February 2015, 17:01:19 »
1 hour tops on v6 to change
Remove bagpipes.
Remove alternator belt.
Remove alternator.
Knock sensor is bolted to the block behind were the alternator was  :y
Refit it the reverse  ;D
One thing to remember ................ carefully clip the sensor wire up and be careful when refitting the alternator because its very easy to trap the sensor wire and knacker it  ;)
Not like i'm talking from experience or anything  ::) :-X :-[ ;D
Re: Knock Sensor
« Reply #4 on: 16 February 2015, 17:10:17 »
Alternator out?  :-\  I was hoping to get away with not having to do that....  :( :( :(  ::) ::) ::)
Re: Knock Sensor
« Reply #5 on: 16 February 2015, 17:12:01 »
Where's Gollum when you need him and his long thin fingersss... ;D
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: Knock Sensor
« Reply #6 on: 16 February 2015, 17:20:52 »
Tried it both ways after I trapped the friggin wire replacing mine
Unless you have very skinny hands, its much less hassle if you stick a 15mm spanner on the tensioner, remove the belt then remove the alternator   :)
Re: Knock Sensor
« Reply #7 on: 16 February 2015, 18:22:09 »
Sorry Tig, none here mate
Re: Knock Sensor
« Reply #8 on: 16 February 2015, 20:23:53 »
Thanks Rob.  :y
Re: Knock Sensor
« Reply #9 on: 16 February 2015, 21:12:57 »
Anyone got a part number and price for one of these?  :)
