Author Topic: Poly bushing the wishbones  (Read 4883 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« on: 20 February 2015, 18:46:40 »
Just a quickie ................. The front wishbone kit and poly bushes have arrived.
I've just read the guide but have a quick question ?
Removing the rubber bush looks fun in a mindless violence sort of way  ;)
Removing the outer metal sleeve may need a more gentle approach  ;D
Right, these purple poly bushes .............. do they need warming up first or just add a little of the lubricating grease supplied and ram the bugger in cold ?
Just thought, that sounds rather NWS but you get my drift  ;D ;D
    • 530D M Sport, 330i Coupe
Re: Poly bushing the wishbones
« Reply #1 on: 20 February 2015, 18:55:27 »
You'll find they just slot in with no effort (they aren't a tight fit like the originals that need a 10 tonne press) but do coat them in plenty of copper ease otherwise they will squeak.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #2 on: 20 February 2015, 18:57:29 »
Can the original metal outer sleeve be left in or is that a no no ??
« Reply #3 on: 20 February 2015, 18:58:12 »
N, got to be removed, carefully.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #4 on: 20 February 2015, 18:59:51 »
Okay, message received  :y :)
Just got too find the best deal for a set of B4's now then is playtime  :y :y
« Reply #5 on: 20 February 2015, 19:45:22 »
I have to do this job soon, so apologies to Mr Gonads for butting into his thread, but do the wishbones have to come out or can you just drop the front out of the hanger?  ???  :-\
TIA  :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #6 on: 20 February 2015, 19:53:17 »
TIA  :y
Apparently the front one can be changed in situ but I have the honour of destroying the front one on a new set  :y
« Reply #7 on: 20 February 2015, 20:37:51 »
TIA  :y
That's the preferred approach to the job, especially given the cost of realignment... Better to start with a clean slate :y
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #8 on: 20 February 2015, 21:36:18 »
Balance motorsport was the best deal there was a couple of months ago for the B4s - and slow down! I'm poly-ing my wishbones and fitting my B4s this weekend, don't beat me to it!  :D
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #9 on: 20 February 2015, 21:48:01 »
I wish because this car is really starting to get scary when you hit the brake.
I've been hanging on so I can do it all together  :y
I've go to travel down to Sleaford in morning to pick up that corsa for mini me so you should be safe  ;D
What did you pay if you don't mind me asking ?
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #10 on: 20 February 2015, 22:18:39 »
Can't wait to get this done on mine. Along with the 300 other "vital" jobs I want to fanny around doing...
pauls
  • By the sea minehead
    • Bmw x3
« Reply #11 on: 20 February 2015, 22:47:11 »
TIA  :y
That Chris Gixer fella has done two of my cars both times jacked the front up undid the bolt then with a drill and a jigsaw did the business popped in the polys and job done :y
« Reply #12 on: 21 February 2015, 10:31:25 »
My ATP wishbones are only 6 months/8000 miles old and the front bushes have gone.  :'(
However I think that I hit something hard as my handling issues have suddenly happened.  My nearside front camber was visually out and when I took it in for adjustment it was -2.48, hence it destroying the tyre within a week!  ::)
So I'm reluctant to change the wishbones again, but I'll have to get under and have a proper look at the rear bush and the ball joint.  ::)  :-\  If changing the fronts was good enough for Mr Gixer...  :y
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
« Reply #13 on: 21 February 2015, 12:13:33 »
Could it go that far out just from the bushes starting to go?
« Reply #14 on: 21 February 2015, 12:21:08 »
Don't think so.  :-\  I reckon I hit a pothole or something hard.  ::)
