Author Topic: removed sl suspension question  (Read 2263 times)
drinksoptional
  • Scotland
    • 98 3.0 elite estate
« on: 20 February 2015, 22:51:30 »
Hi yesterday I removed the sl shocks and replaced them with kyb shocks . I pulled fuse 27 I'm guessing that's the one for the compressor  only. Can anybody confirm this and anything I should of done. Thank you
Re: removed sl suspension question
« Reply #1 on: 21 February 2015, 00:04:51 »
Remove the sensor, all the plumbing and the compressor ::)
drinksoptional
  • Scotland
« Reply #2 on: 21 February 2015, 00:12:00 »
Aye the compressor next on list  erm  where is it in boot next to cd changer ?
« Reply #3 on: 21 February 2015, 00:24:14 »
Completely opposite end of car ....... under the front offside wing/bumper  :y
« Reply #4 on: 21 February 2015, 00:55:38 »
Follow the plumbing ;D
omega2018
    • MercCL500 Omega2.6ManElit
« Reply #5 on: 21 February 2015, 01:04:06 »
pulling fuse 27 will disable the rear cigar lighter.  when i removed the sl i eventually put 27 back in and removed the relay instead, the pump is still in situ, seemed to work. search on here to find which relay it is, i think it is the second from left under the steering wheel.
« Reply #6 on: 21 February 2015, 10:27:22 »
Yank the relay, next to (and identical to) the headlight main beam.
« Reply #7 on: 21 February 2015, 23:35:39 »
Yep. Nothing more required. Can leave fuse 27 in place as a result which keeps the rear 12v socket working.
However. If you ever intend to ever re fit self levelling, consider that the pump WILL seize if left unused for a while.
drinksoptional
  • Scotland
« Reply #8 on: 22 February 2015, 15:05:41 »
Ah right  other side thanks .  The pump psi  anybody know what it is  got an offroader project  onboard air compressor be handy .
it sits lower at rear compared to front  think new springs will be needed
