Climate control problem
Started by Tony H, 22 February 2015, 12:41:11
Tony H
Hi all, as title it will only blow hot air when the unit is set on "Hi" any ideas what the cause may be?
TIA
Tony
zirk
Tony H
Yes zirk heater set at maximum
sjc
What MY?
On the pre-facelift climate, there is a fan built into the control unit to sample the air temp from the cabin and adjust as required.  If the fan fails or gets gummed up with fluff/dust then you get the problem you have.  Easy way to check is to put a small piece of tissue paper over the intake (cut-outs above the centre 2 controls) and if it doesn't stay put with the small amount of suction then the fan ain't turning.
Have you done the 'reset flaps' procedure?
Facelift may be a completely different setup.
Quote from: Tony H on 22 February 2015, 12:41:11
TIA
Tony
Probably a faulty outside temperature sensor. What temperature is displayed on the MID?
Quote from: Andy H on 22 February 2015, 15:03:37.....
.... Probably a faulty outside temperature sensor. What temperature is displayed on the MID?
that assumes Tony's car is a facelift  :-\
Quote from: sjc on 22 February 2015, 14:20:41
What MY?
FL is similar
Tony H
TIA
Tony
Thats a good point the outside temp sensor is displaying 44 degrees I think its telling fibs cos it's rather freezing up here. By the way my miggy is a facelift
Quote from: Tony H on 22 February 2015, 15:59:52.... By the way my miggy is a facelift
It's that long since I've seen you I couldn't remember  ;)
TIA
Tony
That's the problem identified then.
A new sensor is cheap and easy to fit which may fix the problem. If it doesn't then you need to look for corroded connectors and damaged wiring in the loom the sensor shares with the front foglights.
sjc
I've got a sensor here, can double-check it's working.
Tony H
Quote from: Andy B on 22 February 2015, 16:03:05
Yeah not been able to make any meets for a while hope to catch you at the next one :y
Quote from: Tony H on 24 February 2015, 19:07:01
Like wise ...... see you then  :y
I'll park my Merc in a corner out of the way  ;) ;)
