What will stick leather to plastic?
Started by sjc, 22 February 2015, 20:31:40
steve6367
Quote from: Taxi Al on 23 February 2015, 09:00:29
The issue we had was that the leather was simply to thick to fit, and completely the wrong shape... which was frustrating as it looks like a nice cosmetic job :-\
Mine were cheap eBay ones and fit very well, I will dig out a link  :y
sjc
Quote from: Nick W on 22 February 2015, 23:30:00
Returning to the question; you want the sort of impact adhesive that trimmers use for exactly this sort of job.
Spread a thin coat on both the plastic and the leather, and press them together. Hold for a few seconds and you're done.
Do you know what they use Nick?
I used heavy duty aerosol carpet adhesive from local Travis Perkins for my alcantara door panels :y
Quote from: sjc on 23 February 2015, 10:38:25
The stuff I have was bought from a trimmer and is in a white can marked 'impact adhesive'.  Clearly repackaged from a larger container.
You can get it in aerosols from Home base etc, and while it's not very good will work OK for this sort of job.
Webby the Bear
I purchased some two part epoxy at the weekend to get plastic to metal to stick. Would that work?
RIP Paul Lovejoy
The Sheriff
Quote from: Webby the Bear on 24 February 2015, 20:44:30
I don't think so. Araldite type of adhesive dries rock hard and even the rapid stuff takes agood while to cure. Something a bit more flexible needed here. The impact adhesive suggested right at the start is the way I'd go.
Webby the Bear
Quote from: STMO on 24 February 2015, 20:49:29
Fair enoUgh mate  :y
RIP Paul Lovejoy
Quote from: Webby the Bear on 24 February 2015, 20:53:34
Fair enoUgh mate  :y
You need an impact adhesive ...... something like Evostick - you can then sniff what's left!  ;D
Webby the Bear
Quote from: Andy B on 24 February 2015, 20:55:45
Fair enoUgh mate  :y
Need some of that after dealing with the muppets at Hellfrauds today  ;D
RIP Paul Lovejoy
Copydex should do the job!
Stuck 100's of badges to my campfire blanket in 1980 and they are still on now, all these later................. :y :y
Rods2
Ukrainian solution you need nails, sold by the 1kg bag, drill holes, bend them over on the inside, job done. :o :o :o Self tapping screws, well you have to buy them individually, from behind the counter glass at highly inflated prices, so Ukrainian's use 6" sorry their metric, 150mm nails for everything. ::) ::) ::)
sjc
^ sometimes brute force gives a lot of satisfaction  ???
Diamond Black Geezer
I said it a few posts ago in this thread, and of course everyone can go their own way, but I fitted a gaiter (the wrong one, I might add, PFL on a FL so a little too short) with a plain old ordinary cheap hot glue gun about 4, probably nearer 6 years ago, and it's been in daily abuse since, and not come off.  :y
sjc
Cheers for the replies guys. If I can't find the tube of Bostik I'm sure is in the garage somewhere then I'll get the glue gun out.
I'll report back with the outcome  ;)
steve6367
No adhesive here and it's still on  :y
