What will stick leather to plastic?
Started by sjc, 22 February 2015, 20:31:40
sjc
I bought a new leather handbrake gaiter and need to attach it to the plastic frame - the original one was stapled on but I don't have anything that's powerful enough to put the new one on like that so was thinking best to glue it on somehow.
Anyone done this?
Think I may have some bostik impact adhesive kicking about, would that work?
Yes that was going to be my suggestion. As a guess.
The Sheriff
I reckon, on your bostik impact adhesive tube, it will say "Sticks leather to metal"  ;D
sjc
I'll confirm that if I manage to find the damn stuff  ;D
Tiger Seal & Sikaflex sticks anything to anything  :y :y
Can't you reuse the old staples by using the existing holes in the plastic & making new holes in the leather for the staple to go through?  :-\
sjc
The old staples broke up on extraction  :(
Quote from: sjc on 22 February 2015, 22:13:13
TIG/MIG welding wire?  ;) I used some stainless filler wire as staples to re-staple clips to the edge of the Smart's carpet  :y
Said staples don't actually pass through the plastic... They merely locate the gaiter whilst they are heat welded in place...
Good luck making replacement fit...
The Sheriff
No, no. This is a technical question, so lets be technically correct. YOU broke the old staples....didn't you? Eh? Eh?
Quote from: Taxi Al on 22 February 2015, 22:26:18
Said staples don't actually pass through the plastic...  .....
I'm sure sjc knows what a staple looks like .......  ::) ::)  ;)
Quote from: Andy B on 22 February 2015, 22:10:26
Tiger Seal and Sikaflex.....? Is that like a new Araldite type thing...? Squeeze two tubes together and mix?  ???
The Sheriff
Quote from: Andy B on 22 February 2015, 22:28:20
Our local staples has closed. It's a macdonalds now.
Quote from: Doctor Gollum on 22 February 2015, 22:28:45....
No. It comes in a mastic tube ...... a bit like 'No Nails' ...... they stick all kinds of automotive bits to cars with it these days - rear spoilers etc  :y
Quote from: STMO on 22 February 2015, 22:29:41
I once saw oof described as "the superbly technical omega owners forum" you know.
sjc
Quote from: STMO on 22 February 2015, 22:26:59
Well, yeah sort of  :-[  ;D
