air bed puncture
Started by Andy B, 24 February 2015, 20:33:06
It's a kiddies airbed that has its own cover/sleeping bag.
Any suggestions on a repair? Trouble is, the hole is right on the edge of where it's been heat welded together so a patch isn't going to  work.
I'm tempted to give it a dab with a hot soldering iron but I can envisage burning a hole right the way through. Or even maybe a dab of Tigerseal over the hole?
TIA  :-\ :-\
The Sheriff
If you can't repair it as is, try making the hole even bigger and giving yourself something to work with.
Quote from: STMO on 24 February 2015, 20:36:43
but as said, the hardest bit is that it's on the edge of where the 'weld' is  :-\
The Sheriff
Quote from: Andy B on 24 February 2015, 20:39:47
TBH, I don't think much is going to work under those conditions. Awkward repair, quite high pressure and a fidgety kid wriggling around on it.
Quote from: STMO on 24 February 2015, 20:44:06....
Agreed.  :( It's used for my niece's little lad. The family don't seem to be able to visit us without breaking something  ;D ;D
al brown
#5
I repaired ours by using some tent seam sealer goo, can't remember the exact stuff, think it came with the tent. I cleaned the area and made sure it was dry, added a bit of sealer to the hole with the bed deflated and then when it  stated to go off I put a piece of fabric tape over it, the tape I used is almost air tight as it is anyway. I then ended up effectively with a flexible rubbery patch with the sealant fixing the hole and the tape protecting and giving strength to the sealant. Been fine for the last 4 years.
Of you can wait till next week I can post you some of the tape, it's green but it's very good stuff.
If it aint broken, you aint trying hard enough
Quote from: al brown on 24 February 2015, 21:25:34
Cheers Al ...... I'll look out for some tent seam sealer  :y
CaptainZok
Is it that vinyl cloth Andy? I know they patch truck curtains with offcuts of the same and a hot air paint stripper to melt the plastic then a small metal roller to fuse the two pieces together.
TuBy's new whipping boy.
Quote from: CaptainZok on 24 February 2015, 22:11:58
Just plain vinyl. My offcuts of vinyl are missing though ........  ;)
I wonder does Stmo have a tongue in cheak, given the inflatable item in question. ::)
Quote from: Doctor Gollum on 24 February 2015, 22:26:30
I was ignoring the obvious .........  ;)
moggy
Quote from: Andy B on 24 February 2015, 22:30:18
Leave him alone he is from Amsterdam. ;D ;D
moggy
Face cheak or arse cheak,your spelling is as good as mine. ;D ;D
