Author Topic: Fault codes......  (Read 1505 times)
Boons
  • Aylesbury
    • Omega 2.5 V6 Manual
Fault codes......
« on: 27 February 2015, 10:23:28 »
Hi guys,
I had the car serviced yesterday and they picked up the following codes, turned the light out but of course 2 miles down the road, the light came on again.
It's an October 99 manual, saloon 2.5 V6 petrol.
The codes are:
Air regulation inlet valve 59
Check lamp low voltage 135
Revolution signal - no signal 31
Any ideas?
Cheers!
Re: Fault codes......
« Reply #1 on: 27 February 2015, 16:36:10 »
Does car run ok?
Codes are -
31   No Engine RPM Signal - normal when engine not running
59   Intake Manifold Valve 1 Voltage Low -  check the solenoid plug is pushed fully home on Intake Manifold Valve 1
135   Telltale (Checklight) Voltage Low - related to the bulb in the instrument panel for the engine ECU light.....is it working?
HTH
Boons
  • Aylesbury
« Reply #2 on: 03 March 2015, 15:50:10 »
Does car run ok?
Codes are -
HTH
[/quote
Hi Thank you.
The car drives well apart from an occasional midfire under load at low revs.
Is the ECU light the management light?
« Reply #3 on: 03 March 2015, 16:05:52 »
It's one of them :y
