ABS sensors
Started by EMD, 01 March 2015, 18:10:30
EMD
Anyone removed them without breaking them  ::) I need to take mine out for a spring clean , i guess a wide flat blade implement will help persuade them out if the bolt comes out first  ::) :-\
Omegatitis
biggriffin
Broke them every time.,except the ones I then have to remove from a car at the breakers,its called sods law. :)
Makes ya swear,
Hoof'land storeman.
EMD
£15 a pop bran new ... better order some in , then take back what's not needed . Tool of choice , hammer an chisel  :-\
Omegatitis
4x4
If you cant get oem spec for front,they use mazda sensors,also check abs rings on front discs as they corrode and fall apart.
Quote from: 4x4 on 01 March 2015, 21:15:32
Uncommon on Omegas. Very uncommon.
Quote from: TheBoy on 01 March 2015, 21:56:06
But not on abused Isuzu Mus ::)
Not part of the disc on an Omega either...
Quote from: Taxi Al on 01 March 2015, 21:58:09
Ah, well, if you buy a useless shitbox, my sympathies will go elsewhere ;)
EMD
All ye ole doubters  ;D  :P :P :P
Omegatitis
