headlights
Started by badmuver, 01 March 2015, 18:52:43
badmuver
Was cleaning the car today and notice one off the headlights was cloudy
right one  https://www.dropbox.com/s/tri10z2nxi7oxdu/2015-03-01%2012.00.57.jpg?dl=0
left one    https://www.dropbox.com/s/puzbnbr7rhpl4w4/2015-03-01%2012.00.52.jpg?dl=0
IS there a way to clean it
Quote from: badmuver on 01 March 2015, 18:52:43
I've just done this for my MOT.
How you do it depends on what you have available to you. If you have paint refinishing supplies like rubbing compound, polish etc then use that. There are specific things available for perspex or plastic, like aircraft canopies. You can also get specific kits for headlights which are expensive , but are OK if you don't have anything.
Whatever you use, buy a couple of sheets each of 1000 or 1200grit wet&dry paper and use that first with plenyt of soapy water in a criss-cross pattern. Masking tape around the wings and along the bumper are a good idea.
It's only a small area, so powertools aren't necessary; you should be able to do both lights from a really crap state to sparkling clear(mine look like new) in an hour.
kevinp58
Scotch 3m do a brilliant kit on amazon for around £15 it really cleans them up like new.  :y :y
badmuver
cheers, so it is on the outside  ??? , I thought it was on the inside and have to take it apart  >:(
