I Think
Started by Steve B, 03 March 2015, 21:17:29
Steve B
That will work without glue  :D :D :D :D :D
Valve is mega tight in cap.. Was a mole grips job to get it on the collar  ;D ;D ;D
That's much neater than mine which has loads of silicone around the inside to seal it!  ::)  Still works though.  :y
BazaJT
O.K,O.K. I admit it mega blonde moment here.Tell me why are you fitting a tyre valve to a header tank cap?
Steve B
I used a hot knife to chop the 2 safety valves off,So i never needed to make a spacer  :y
hawke113a
its ok baza....i had a moment too...cos ive no idea why either lol  :D
Varche
To pressurise cooling system. Great for finding leaks and weak points you never knew you had! :y
Steve B
Please note
This is not my idea... All credit goes to  Razzo
http://www.omegaowners.com/forum/index.php?topic=90598.0
Common procedure for finding coolant leaks is to pressurise the cooling system. Then see where the coolant leaks out from.
There's numerous ways, including fitting a Schrader valve in the coolant cap. You can also pull a coolant pipe of the throttle body, clamp the other pipe, then fit a blue footpump connector of the type used to blow up footballs etc and apply pressure that way.
Only needs about 10-20 psi tops. Then you can examine the valley ov the v6 and associated coolant system foe leaks.
Doesn't work with HBV necessarily as there two settings that could cause it to leak. Ac on or ac off. This is best tested visually with engine run up to temp. first and cycling the ac on and off before the pressure test.
...ime. :)
Some rekon adding die to the cooling system helps. Utter rubbish imo as the coolant already has a die in it and you can't see the die until you see the leak. ::)
But each to their own as they say ;D
Steve B
Quote from: Doctor Gollum on 03 March 2015, 23:56:59
Quote from: dbug on 03 March 2015, 23:45:22
Can't be rsed Mr G
Quite right Dbug. Pointless isn't it.
I'm off night fishing'ses. ;)
Now you have my attention  . what you after chris...  :-\
Too cold for the carp lark  ;D
Quote from: BIGtime on 04 March 2015, 00:08:21
Can't be rsed Mr G
Raw and rigglin' Big. No chipses.
The rock and pool,
is nice and cool,
so juicy sweet.
Our only wish,
to catch a fish,
so juicy sweet!
Tbh I think I've caught all I'm going to tonight.  :y
Oddly enough, it's Thursday... Hoooowwwwl... ::)
When I go fishin' fishes ::)
Quote from: BIGtime on 03 March 2015, 22:50:20
Please note
I think you need to go back further than that....... :y
BazaJT
Ah,I see said the blind man!!
