No drive.
Started by Field Marshal Dr. Opti, 05 March 2015, 12:02:03
Put the Omega in reverse with the gear selector light illuminated.......but no drive. :-\ Like being in neutral.
Fine in drive.
On the second attempt at reverse it worked fine. Strange.
chrisgixer
Codes?
Fluid level?
Serviced atf ?
Diamond Black Geezer
I'd assume it's the plate that gets covered in oil, the selector sensor jobby. Underneath the the car, on the left (I think) side of the box, quadrant shaped, undo the screws, and clean with degreaser/electrical contact cleaner etc.
Also while under there check the oil levels as suggested above.
Quote from: Diamond Black Geezer on 05 March 2015, 13:12:44
Reverse is selected by a mechanical + hydraulic process, so it won't be an issue with the selector switch, IMHO. Low fluid level is the favourite.
Ahh fair enough.  :y cleaning the switch worked wonders on a friend's car - but that wasn't on reverse. Good to know  :)
The Sheriff
Quote from: Doctor Opti on 05 March 2015, 12:02:03
Fine in drive.
£250.
henryd
Quote from: STMO on 05 March 2015, 15:45:48
Fine in drive.
£250.
Very generous Esty,I was going to pitch a ton on it ::) ;D ;D
other rides
Doctor Smeagol
Fine in drive.
£250.
...saved in garage bills. (Hopefully)
Onansists always think outside the box.
