Author Topic: omega 3.0 MFL  (Read 2378 times)
swordfish
  • manchester
    • 3.0 omega elite fl / 2000
omega 3.0 MFL
« on: 06 March 2015, 16:07:01 »
Looking for mods to up rate the performance  ,   fire away with your ideas
                               thanks
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: omega 3.0 MFL
« Reply #1 on: 06 March 2015, 16:28:51 »
Last 3.0 I did was (as I had most of the bits) was on a MV6 Manual Estate,
Remap (Chip), Enlarged Throttle Bodies, Gas Flowed TB's and both the Intake Dividers, matched (Ported) the Intake to Heads (never took Heads off, otherwise would have done a bit more), KN Air Filter (No Oil, dont ask), messed around with wider funnelling the Cold Air Feed, Cats Back Stainless Steel Performance Exhaust System (not too loud) and 3.9 LSD Diff on a 3.7 Manual setup (Actually got fed up with that at +70mph, so fitted a 3.7 LSD in the end).
Was think about doing a full De Cat and running on LPG for MOT time but never got that far.  :-\
swordfish
  • manchester
Re: omega 3.0 MFL
« Reply #2 on: 06 March 2015, 18:01:01 »
were do you get chip / remap from  :y thanks
zirk
  • Epping Forest
Re: omega 3.0 MFL
« Reply #3 on: 06 March 2015, 19:00:00 »
Local Chip / ECU man, pm sent.  ;)
serek
  • huntingdon
    • 3.2 mv6
Re: omega 3.0 MFL
« Reply #4 on: 06 March 2015, 21:55:01 »
Was think about doing a full De Cat and running on LPG for MOT time but never got that far:-\
that's what I run on mine , but its too loud with out cats .maybe will fit some 200 cell cats
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: omega 3.0 MFL
« Reply #5 on: 06 March 2015, 22:30:19 »
Just fit small, clam shell silencer boxes, or bomb silencers.
Hoof'land storeman.
MV6Matt
  • London
    • No car since 2022....
Re: omega 3.0 MFL
« Reply #6 on: 07 March 2015, 10:16:11 »
The 'cherry bombs' from the United States?
Matthew
(thanks Ian)
