Author Topic: Heater only blowing cold  (Read 14208 times)
Kate
  • Cornwall
    • Drives people mad
Re: Heater only blowing cold
« Reply #15 on: 30 March 2015, 15:38:08 »
Reset? Hold off and auto together until the vents start buzzing.
Thanks Chris, I tried that but it didn't work.
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
« Reply #16 on: 30 March 2015, 15:40:53 »
Cycling the directional arrows, do they respond? Does the re circ flap respond?
Kate
  • Cornwall
    • Drives people mad
« Reply #17 on: 30 March 2015, 15:42:56 »
I'll go and test it.
Kate
  • Cornwall
    • Drives people mad
« Reply #18 on: 30 March 2015, 15:57:21 »
Yes everything responds.
Always get cold air through front vents and hot air through the rear.
« Reply #19 on: 30 March 2015, 16:29:35 »
But if you select windscreen only, do you still get air in the foot wells and out the vents?
« Reply #20 on: 30 March 2015, 16:32:56 »
3.2 is other way around for me, cool at rear vents hot through others. Toes get nice and hot, but rear still cool.
Tried flushing matrix, resetting system (via the auto-circulate) holding auto ect. Arm thing that controls vents appears ok, still sod all.
Now I just force the air to face and feet via the controls and it's fine, although rear vents still not great.
Kate
  • Cornwall
    • Drives people mad
« Reply #21 on: 30 March 2015, 17:28:24 »
I don't think so, I'll have to check.
Kate
  • Cornwall
    • Drives people mad
« Reply #22 on: 30 March 2015, 21:45:10 »
I found this on the WWW:
"The climate ECU had to be hard reset twice - a hard reset consisting
>> of disconnecting neg and pos battery terminals and dis/re-connecting
>> both ECU connectors.
>> Joy of joys when hot air came gushing out of the correct vents ...
>> WOOH ! Seems a single reset just wasn't enough."
"The ECU is incorporated in the climate control panel.
Just remove the dash switch panel and there are two connectors plugged in
the back of the climate control unit/ECU - the yellow one on the N/S can
come out without invitation, so make sure it stays put (it unplugs by
pulling out the black plastic retaining clip).
After the first hard reset, I had different temps on left and right.
Good luck ta ya, dude."
Would this fix it? ::)
« Reply #23 on: 31 March 2015, 10:12:28 »
Let us know the outcome when you do.....as its a critical key indicator as to the cause. :y
chrisgixer
  • Woking ham
  • Banned
« Reply #24 on: 31 March 2015, 12:29:04 »
Does sound like incorrect opperation from the cc panel.
On the face lift, quite often I find the reset doesn't work, unless it's done with engine off, key in ignition position 2. ...?
Kate
  • Cornwall
    • Drives people mad
« Reply #25 on: 31 March 2015, 13:26:00 »
Right, I've just been out and tested it.
I put the blower on full, turned the temp to Hi and switched to windscreen only. The engine was at normal temperature.
Result:
1. A little cold air was coming through the front side vents.
2. Nothing came through the middle front vent.
3. Lots of hot air was coming through the rear vents.
4. I didn't notice any air in the footwells.
5. Some cold air was blowing on the windscreen.
I hope this means something.
Thanks very much for helping. :y
« Last Edit: 31 March 2015, 13:28:03 by Kate »
Kate
  • Cornwall
    • Drives people mad
« Reply #26 on: 02 April 2015, 11:06:17 »
Does anyone know the answer to my problem? :y :-* :-* :-*
Kate
  • Cornwall
    • Drives people mad
« Reply #27 on: 03 April 2015, 12:11:24 »
Would it be worth buying a Haynes manual, do you think? :y
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #28 on: 03 April 2015, 13:10:15 »
Haynes manuals covered the P/F/L and M/F/L models and not the F/L,however how much if at all this affects things in regard of possible differences in operation I don't know.
Kate
  • Cornwall
    • Drives people mad
« Reply #29 on: 03 April 2015, 15:22:08 »
No-one seems to know the answer to why I can only get warm air to the rear vents and not the front ones.
I don't know where else to look.
Thanks for the help. :y
Pages: 1 [2] 3 4  All   Go Up
