Author Topic: Advice please  (Read 5862 times)
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Advice please
« on: 11 March 2015, 22:54:59 »
when changing the HBV on 2.2cd I removed the scuttle, I noticed that one of the hoses was burst anyway ordered part from Vauxhall so left scuttle off. had a bit of an emergency that evening and had to use the car for a short distance, anyway did it not start to rain, after about 5 mile  car starts rattling and EML came on. Fault code p0303 misfire in 3. Have changed plugs still code appears, put in another coil although not new and code still appears. reason for changing HBV was no hot air in the cabin, have some white smoke from exhaust. Is my head gasket blown or is there something I've missed that could have got wet I.e.
« Last Edit: 11 March 2015, 22:59:40 by Raymienets »
Re: Advice please
« Reply #1 on: 11 March 2015, 23:32:53 »
Any steam from exhaust or further coolant loss?
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Re: Advice please
« Reply #2 on: 11 March 2015, 23:41:24 »
Have started having coolant loss over the last few days.
Re: Advice please
« Reply #3 on: 11 March 2015, 23:42:55 »
Any steam from exhaust? Smell in header tank?
Misfire at idle but ok at higher revs (before it shuts down the injector)?
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Re: Advice please
« Reply #4 on: 11 March 2015, 23:57:42 »
Smoke or steam when sitting at lights. Have not noticed any smell from header tank but was foamy. Feel it chugging also on idle
Re: Advice please
« Reply #5 on: 12 March 2015, 00:00:23 »
If you're getting Definite steam from exhaust then likely HG
Seen a lot of 4 pots fail lately!
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Re: Advice please
« Reply #6 on: 12 March 2015, 00:07:00 »
Thought so. Cheers.
Re: Advice please
« Reply #7 on: 12 March 2015, 00:09:15 »
Easy enough job if you're ok twirling a few spanners? :y
flyer 0712
Re: Advice please
« Reply #8 on: 12 March 2015, 20:40:42 »
whats the mileage......i  have had two that have blown before 100,000 miles....common problem with 2.2... :'( :'(
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Re: Advice please
« Reply #9 on: 13 March 2015, 11:43:27 »
This is the second time its happened, so need to try and do it myself as its not financially worth it to pay hundreds to get it fixed again.
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Re: Advice please
« Reply #10 on: 14 March 2015, 16:55:53 »
too daunting garage it is. LOL
Re: Advice please
« Reply #11 on: 14 March 2015, 22:24:49 »
Get rid! You will only be throwing good money after bad believe me I know!!! After 3...yes THREE 2.2's all blowing headgaskets more than once plus gearbox problems I wouldn't have one given free! Stick to the full fat V6 versions
Re: Advice please
« Reply #12 on: 15 March 2015, 09:25:31 »
Before condemming it, pull out the coil pack and post up a pick of it, esp the bit around pot 3 :y
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
Re: Advice please
« Reply #13 on: 15 March 2015, 12:54:13 »
Do the 2.2's smoke from the exhaust like the 3.0l does?can't say as I've ever noticed but could it just be this and water loss down to such as HBV?
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Re: Advice please
« Reply #14 on: 15 March 2015, 22:25:19 »
Curious now was getting an error code P0303 misfire in 3. so why did you mention 3.
classic symptoms of gasket as its happened before.
