Author Topic: Replacing main battery  (Read 5116 times)
DrAndyB
  • Neston / Cheshire
    • 2.5 V6 CDX Manual (MFL)
« on: 13 March 2015, 22:32:53 »
Looks like need to treat her to new main battery.
What is the recommended process for removal and fitting ?
I have a MFL 2.5V6 CDX on a V plate.  Looks like there is a 72Ah one same dimensions  :y
Am I correct that process is:
  • Turn ignition off and remove key
  • disconnect negative within 15 sec
  • then disconnect positive and make cuppa
  • remove old and locate new battery connecting positive terminal first then negative
  • enter radio code and start car as normal
I read somewhere about needing to reset key immobiliser and windows ???? Or is this not necessary ?
Thanks in advance.
Andy.
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: Replacing main battery
« Reply #1 on: 13 March 2015, 22:46:15 »
No tea break  :y
« Reply #2 on: 13 March 2015, 22:52:15 »
You will need to reset one touch window operaton plus sunroof [if fitted].  You will also need radio code.
DrAndyB
  • Neston / Cheshire
« Reply #3 on: 13 March 2015, 22:52:54 »
No tea break  :y
Ahh, I read somewhere to let things discharge to avoid Airbag light coming on ?  Unless that is on the Face lift only and so not needed on my MFL so culpa when all done ! ?
« Reply #4 on: 13 March 2015, 22:54:07 »
Thanks in advance.
Andy.
Correct on all counts. You can make life a bit easier by slackening the -ve battery terminal off before you start  ;)
« Reply #5 on: 13 March 2015, 22:56:23 »
You have airbags on your MFL too  ;)
DrAndyB
  • Neston / Cheshire
« Reply #6 on: 13 March 2015, 23:01:59 »
Following procedure will not cause Airbag light to come on following new battery reconnection ?
« Reply #7 on: 13 March 2015, 23:09:29 »
You'll be OK just swapping the battery.
You'll only have problems if you have any of the airbag system disconnected and turn the ignition on (with the battery still connected) It'd need re-setting even if you fix the fault or reconnect it all
DrAndyB
  • Neston / Cheshire
« Reply #8 on: 13 March 2015, 23:17:06 »
Cheers.  Sounds like should be simple.
Any advice on how to reset the windows and sunroof ?  ???
« Last Edit: 13 March 2015, 23:18:44 by DrAndyB »
« Reply #9 on: 13 March 2015, 23:29:14 »
Please read the manual  ;) ;D ;D
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #10 on: 14 March 2015, 07:09:49 »
Never re-set a sunroof myself so don't know on that bit,but windows easy.Just press and hold each window switch to the closed position and after a second or two you should here a faint "click"and that's that particular window sorted.
DrAndyB
  • Neston / Cheshire
« Reply #11 on: 14 March 2015, 08:36:33 »
 :y Cheers all  :y
What can go wrong !  :D
Must lube the securing bolt as not moved since Fritz put in on 15 years ago in Germany  :o
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #12 on: 14 March 2015, 08:48:56 »
:y Cheers all  :y
I don't think you have a battery that is 15 years old :-\
DrAndyB
  • Neston / Cheshire
« Reply #13 on: 14 March 2015, 10:34:09 »
I do have a 15 year old battery  ;)  I think its a world record  :D
I have had the car from 6 months old and still has the Original GM Battery on  :y and never been replaced  8)
She has been getting a little slower on turnover and battery I suspect now getting "Tyred !"  Green indicator on battery stopped being green a few years ago !
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #14 on: 14 March 2015, 13:12:14 »
WOW !!!!
Just got a new GM battery for the Elite from the local dealers, £53 + vat. I bet it will not last 15 years, mind you I bet the car will be gone long before that  :y
