Author Topic: Facelift saloon towbar connector - where?  (Read 1052 times)
johnny_boy
  • hertfordshire
    • omega 2.0 gls auto v reg
« on: 17 March 2015, 16:35:08 »
Hi
I have a 99 gls saloon. It is a facelift.  Looking to fit a towbar. Do I have a connector  for the trailer electrics? If so, where can I find it. Can't see it anywhere.
Thanks.
Re: Facelift saloon towbar connector - where?
« Reply #1 on: 17 March 2015, 16:46:55 »
GM kit is plug and play into the rear lights for trailer lighting, Domestic socket is wired to engine bay via a relay :y
Give FG Barnes in Guildford a call as they have/had a supply of GM towbar wiring bits for peanuts :y
steve6367
« Reply #2 on: 17 March 2015, 23:15:36 »
Yes, remove the pastic trim at rear of boot and there is a connector there. You can get a kit as above or just cut connector off and use the wires only if you wish.
You may / will need to change your flasher relay to a 4 pin version (under steering wheel)
Steve
