Wynn's lifter treatment.
Started by Field Marshal Dr. Opti, 20 March 2015, 13:13:42
Snake oil.......or does what it says on the tin?
Better off buying magic beans
Quote from: tunnie on 20 March 2015, 13:15:00
As bad as that. :'(
Fortunately I don't have a cow  I can P/X for the beans. ::)
Does a reasonable job on my 2.6, 3.2 never needed it though as it never suffers any lifter noise.
Quite a few on here will vouch for it - it's the only snake oil that isn't entirely pants.
Quote from: VXL V6 on 20 March 2015, 13:32:19
Agreed, makes a noticeable difference  :y
Maybe I'll give it a whirl.
Leave the beast for a couple of days and she gets a bit arsey when I start her up.
What oil do you use? 10w40 semi or 5w30 fully synth :-\
Quote from: Taxi Al on 20 March 2015, 14:00:02
GM usually.
But this time Fuch Titan 10/40 semi.
Try a couple of oil changes first and see if that helps, if only to clear out any crud that might otherwise get dislodged by the lifter cleaner and clog the pickup. :y
Quote from: Kevin Wood on 20 March 2015, 14:06:49
Every 3000 miles I refresh her lubrication so she is nice and slippery.
If I dip my fingers inside her, and then rub them together, I can tell that she is well looked after. :)
Quote from: Doctor Opti on 20 March 2015, 14:10:06
Every 3000 miles I refresh her lubrication so she is nice and slippy. :)
I should have guessed that you'd be tending to her lubrication with such dedication. ::)
Straight in with the Wynns, then. :y
Reason for asking is that 5w30 is thinner, so tends to drain down more readily, but flip side is that by virtue of being thicker, 10w40 takes a while to reach all the nooks and crannies until it's warmed up, that's where the lifter treatment comes in :y
Only about 100 miles since the last oil and filter change. So now seems as good a time as any.
Does it (Wynn's) work immediately, or will it take a few miles before I notice the difference?
Bigron
On advice from this excellent forum, I tried the Wynn's and it worked immediately - no noises at all!
Thanks gents, as ever, so very helpful.
Ron.
Quote from: Doctor Opti on 20 March 2015, 14:33:38
You should hear the difference as it circulates :y
