Author Topic: doors not open  (Read 2462 times)
faruk1983
  • turkey
    • omega td
doors not open
« on: 27 March 2015, 22:31:34 »
my car door can not be opened. working remote control. the doors will not open the key. the trunk was opened. I walked in. fuse is good. Coming on the right side of the door ^clicks when I press the control button. battery is full. please help.
Re: doors not open
« Reply #1 on: 28 March 2015, 03:45:19 »
Classic drivers door lock solenoid failure ;)
Replace and it should be fine. You can still lock/unlock the car manually with the key, but if the car is deadlocked, you will need to turn the key as far as you can... the door will unlock, but the button will stay down :y
faruk1983
  • turkey
    • omega td
Re: doors not open
« Reply #2 on: 28 March 2015, 06:37:16 »
Doors will not open from the inside and outside absolutely. Only the trunk is opened. The driver's door switch does not turn at all.
Re: doors not open
« Reply #3 on: 28 March 2015, 10:54:37 »
It will, turn it so far that you think the key might break...
Re: doors not open
« Reply #4 on: 28 March 2015, 11:13:46 »
Is the car deadlocked?
faruk1983
  • turkey
    • omega td
Re: doors not open
« Reply #5 on: 28 March 2015, 13:12:07 »
Yes.  Car is deadlock.  Key is not turn.  I pull out center lock. Doors have not energy
Re: doors not open
« Reply #6 on: 28 March 2015, 13:18:36 »
Lower windows.
Mole grips on the lock buttons, lift them up from outside car.
Reconnect central locking and replace drivers door solenoid :y
But first try to turn key. Don't faff about, turn it until you think you will twist the key. It WILL unlock.
faruk1983
  • turkey
    • omega td
Re: doors not open
« Reply #7 on: 28 March 2015, 14:22:31 »
To break the key. But it does not still open. I think I have no energy. Yesterday was immobilized activated when I try to switch. Today is not covered.
faruk1983
  • turkey
    • omega td
Re: doors not open
« Reply #8 on: 28 March 2015, 14:57:49 »
about 4 years ago , the battery is was completely drained. ıt also was opened in this way. battery is changed, and was opened. ı wonder if the power cord is disconnected me. the battery is full. car is run.
faruk1983
  • turkey
    • omega td
Re: doors not open
« Reply #9 on: 08 April 2015, 04:54:45 »
Problem solved. Left front door solenoid completely corrupted. Thank you for the help.
