Pages: [1] 2 3  All   Go Down
Author Topic: Clonking in boot going over bumps, daughter complains. Top shock nut loose?  (Read 6481 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Daughter Catherine, lives in Enfield, London, complains of a loud clonking rear nearside when going over bumps. Getting louder, sha said. She looked in the boot and saw 'a stick thing going up and down about 6"' . Sounds to me like the n/s shock abosrber nut loose of missing. I can't imagine how she saw it doing it. Any thoughts, chaps? I am inclined to drive there, have a look, probably bring the car home to Somerset. The noise frightens her, but I assume it will still drive, just bounce about a bit. Car is an Omega, V reg 2.5 petrol manual saloon.
Ask her where this stick is, and send you a photo.
If moving that much, the body must have corroded away :o
Before doing that I'd get her to take into somewhere like ATS/Shitfit for a free check with strict instructions not to have any work done until she's consulted you.  It might be something simple that needs tightening or it might be a big job and it's not safe to drive.  :-\  Forwarned is forarmed and all that.  ;)
On the other hand if you just fancy seeing your daughter.  :y
Topmount could have failed, in which case you need to establish why... body corrosion or rubber degradation are your two choices there :-\
If moving 6", the shock body must be protruding through? It wouldn't fit through hole in body (unlike fronts)?
terry paget
    • 3 Astras 2 Vectra
My first thought was have her call in the RAC and look at it. She is out until tomorrow midday, but I have a spare key to it. If it is rusted through car may be a wreck, but I would like to get it home to strip for spares. I cannot see why it should be unsafe to drive at modest speeds with a shock absorber missing.
Then you don't understand what the shock absorber does...  :-X
That might have been a tad condescending  :-\
The shock absorber does two things.
Firstly it limits the travel of the trailing arm to about 80% of its range of movement. Without this limit, a decent bump will see the spring escaping, followed by lots of carnage, both for you and other road users...
Secondly it controls spring bounce, by damping the spring reactions to bumps and dips and therefore keeping the wheel in constant contact with the ground.
A failed shock will knock like a bastid, and not provide the second function, so the wheel will behave like a rubber ball, bouncing enough to leave the ground. This would probably make the car near undriveable, but importantly it would still provide the first function.
If the shock mounting has failed, then it might provide damping at the limit of the compression stroke but only when the top mounting stops moving up, whether that is at the inner wheel arch or parcel shelf. However, it won't control the down swing of the trailing arm, so potentially could allow the spring to escape or the wheel to bounce on anything but glass smooth surfaces.
Personally I suggest the following... get the RAC out. If the shock is secure but failed, you could consider driving it to yours, but would be illadvised to do so, knowing it is defective.
If the shock is unsecure, get it recovered to you. No ifs or buts. If it's just failed mounting rubbers, the mounting kit is available from VX for reasonable money, then renew the shocks and mountings both sides. If it's the metalwork that is the issue then strip the wheel arch in and out to properly asses the damage and go from there :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Im just down the road from Enfield, if you wont me to have a look and try and see whats going on.
terry paget
    • 3 Astras 2 Vectra
Gentlemen, thanks for all advice. Thanks for the generious offer Zirk. I tried to ring the girl, she is currently out walking with the Metropolitan Walkers and not answering her phone. I will be in touch when she rings me.
chrisgixer
  • Woking ham
  • Banned
    • Irmscher 3.2 Elite lpg
Rear shock tower is not known for rust/collapsing.
But 6 inches might mean it's banging on the parcel shelf :o. Can't be right surely?
terry paget
    • 3 Astras 2 Vectra
Got car home. Top of tower has come away. Looks mortal to me. I assume the rest of the car is similarly rusty.
https://www.dropbox.com/s/1d0bhk5uivq12f4/shocker50%25.jpg?dl=0
What do you think?
  • Chatham, Kent
    • Ghastly 1.0l Focus
That's pretty bad, and if the rest of the car is that grotty then it won't be worth fixing.
Although I bet that shock has been utterly ineffective for a very long time which will have contributed to the damage.
To me that looks like the result of cracking rather than rot :-\
Was it an ex plod car? Any evidence of similar on tother side?
chrisgixer
  • Woking ham
  • Banned
Has the shock seized?
Pages: [1] 2 3  All   Go Up
