Author Topic: Question re. my Discovery  (Read 5707 times)
Crazycarzowner
« on: 29 March 2015, 20:32:08 »
Right, now then I know I've had a metallic tapping noise coming from the left bank of the Disco for a while, not really getting any worse but annoying. I've listened to it several times and it doesn't sound like a lifter but I can't put my finger on it. It doesn't do it at idle just on acceleration from about 1500 - 2000rpm, then goes away as and when the revs increase.
I'm thinking possibly a cylinder liner perhaps??? Only other thing I can think of. There are no other issues ie. using oil or water, temp gauge sits at normal & I'm at a bit of a loss really. I know I'll probably find out when I strip the engine, but I did plan on using it for a while until I purchase a Skoda replacement................When I eventually get the cheque  ::) ::) ::)
4x4
Re: Question re. my Discovery
« Reply #1 on: 29 March 2015, 20:43:01 »
Which engine is it?
Crazycarzowner
« Reply #2 on: 29 March 2015, 20:49:19 »
3.9 v8
  • Auckland
    • Mazda MPV
« Reply #3 on: 29 March 2015, 20:58:58 »
When my Range Rover makes that noise I tighten up the bolts between the exhaust manifolds and the heads and the noise goes away for a while.
Cast iron Rover manifolds are a bit fragile so I don't want to overtighten the bolts just in case........
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #4 on: 29 March 2015, 21:03:33 »
Pull the valve covers and check that all the valves are opening fully. Round camlobes on the rear cylinders are a fact of life with Rover V8s. But they hide it so well that it's hard to tell without a physical check.
Crazycarzowner
« Reply #5 on: 29 March 2015, 21:31:30 »
Ohh!! that might be a good shout Andy H, I'll check them in the morning. Yeah Nick W I know what you mean about the cams, but the engine itself is quite low mileage 75k. Gonna try the fanimoulds first & go from there I think.
the alarming man
  • medway kent
    • disco V8
« Reply #6 on: 29 March 2015, 23:19:58 »
I would try the manifolds first as my old 86,000 v8 did it until I replaced all the gaskets...then saying that nick is right but always try the cheapest method first :y
« Reply #7 on: 30 March 2015, 08:09:22 »
Cams and followers plus chain setup are normally pretty shot by 60K miles.
Check the exhaust manifolds first (there were some improved gaskets for them due to this issue)
Crazycarzowner
« Reply #8 on: 30 March 2015, 14:25:51 »
Give that man a Mars Bar  :y :y :y :y :y :) :) :) :)
Had a look under the bonnet earlier this morning & 3-4 of the rear-most left hand bank of fannimold bolts were loose. Found the correct socket, prised the retaining flap off and nipped em all up! Runs quiet as a mouse now  8) 8) 8)
Thanks Andy H  :y ;)
« Reply #9 on: 30 March 2015, 21:15:17 »
Result.......... :y :y
  • Auckland
    • Mazda MPV
« Reply #10 on: 30 March 2015, 21:29:51 »
It is true that the cam lobes can wear to almost nothing but they don't make much noise as a result. There is only one cam so a new replacement isn't ridiculously expensive.
  • Auckland
    • Mazda MPV
« Reply #11 on: 30 March 2015, 21:48:59 »
Thanks Andy H  :y ;)
You're welcome. :y
« Reply #12 on: 31 March 2015, 18:16:02 »
Sometimes, OOF manages to surprise me. Great news :y
Crazycarzowner
« Reply #13 on: 31 March 2015, 19:10:15 »
Its certainly the best forum for help regarding any vehicle, as well as the Omega. I'm a member of the Discovery club & posted the same, still had no replies yet!!!
« Reply #14 on: 01 April 2015, 12:14:32 »
There are some improved manifold gaskets, have fitted them to two TVR's (which suffer this issue far more due to the swept manifolds)
