Author Topic: How to deal with rust  (Read 5699 times)
steve6367
Re: How to deal with rust
« Reply #15 on: 09 April 2015, 22:02:43 »
The pins might end up in the boot cubbies or in the sills assuming that they haven't wound uo on the ground...
They are readily available from VX (at a price) :y
Off to VX it is then - think 2 of the pins are in the sill.
« Reply #16 on: 09 April 2015, 22:06:21 »
Give the sill a slap, they might well fall out :y
davieboy0312
  • wishaw
    • 3l V6 saloon
« Reply #17 on: 09 April 2015, 22:15:20 »
When I took the body kit off a didn't need to slap it. Wasn't there to slap
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #18 on: 10 April 2015, 11:53:25 »
Just a tip - as you've removed the arch liner to investigate (as I found out recently one exactly the same on my old girl, sorry to say my rust wasn't as bad so can offer no further advice than you have already been given, 100 per side sounds good - just try and watch them if you can. I had a 'good job' done on enthusiastic recommendation of a family member, it was only me being pedantic that upon getting the car back I chipped away at some of the red lead paint to discover the fresh metal had surface rust on it, that they'd just painted over, must've taken all night / a couple of days being left bare steel to get like that, if the rate of discs rusting is a measure. I digress...)
The easiest way I've found to get them little clips is to pop the header tank off a scrap Omega (it's a single clip you ping out, then push the tank towards the right. Takes all of two seconds) then you can feel under the arch, push the central rod out, catch it in your hand, then nab the clip too, should you wish. All the others are a bit inaccessible, but the header tank one is very easy. Before you know it you'll have a good few spares. Also the arch liner isn't going to fall off if a couple of them are missing, there's them plastic nuts as well that hold it on.  :)
