Author Topic: maf and manifold help needed  (Read 2870 times)
hawke113a
  • leeds
« on: 05 April 2015, 17:01:37 »
im doing the 3ltr conversion to my 2.5 with 2.6/3.2 exhaust manifold...the questions i have is are the 2.5 manifold gaskets the same as the 2.6 and will the 2.5 maf work with the 3ltr conversion....do i need to buy another maf as mine was working fine before...cheers
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: maf and manifold help needed
« Reply #1 on: 05 April 2015, 17:06:02 »
Can't help with the MAF, but the gaskets aren't compatible. You need the 2.6/3.2 gaskets to match the manifolds, as neither have the EGR holes. They're surprisingly expensive too.
« Reply #2 on: 05 April 2015, 18:20:32 »
The gaskets are compatible. In fact its always recommended to use the 2.6/3.2 gaskets on the earlier engines.
  • Chatham, Kent
« Reply #3 on: 05 April 2015, 18:30:50 »
I'm sure that's what I said?
« Reply #4 on: 05 April 2015, 18:32:59 »
Hmmm, not how it reads to me.  But then I am very stupid ;D
hawke113a
  • leeds
« Reply #5 on: 05 April 2015, 18:40:28 »
ok me confused nick your saying not compatible and the boy your saying they are  :-\
  • Chatham, Kent
« Reply #6 on: 05 April 2015, 18:48:50 »
If you lay a 2.5 gasket on a 2.6 manifold, you'll see that they won't work. Been there, done that, and still got the 3.0l exhaust gaskets that came with my head set.
You need the 2.6/3.2 gaskets to match the manifolds. Which is what I wrote the first time!
hawke113a
  • leeds
« Reply #7 on: 05 April 2015, 22:26:18 »
thanks nick...ill get some ordered... :y
